Magic sing et23kr...mics turn on and green light appears, mic works for about a minute but then will flicker and the system jumps to the powering up screen, so I cannot get it to play any music
SOURCE: Entertech mic ed-9000--Mic stopped working
Could be the wiring in the RCA cable.
Swinging mike to and fro can wear through the power wiring inside the cable.
I'm on my 3rd cable.
Manufacturers have said they recognise this is a common fault with product but it seems they are not taking any steps to rectify.
I found that using the mike with batteries sometimes works.
If you get a new cable may be a good idea to reinforce the top 12 - 18 inches of the cable to avoid same problem in future.
Posted on Apr 24, 2008
SOURCE: Vocals disappear in parts using this mic
It is very common to have the squelch on the receiver set at full or much too high. With the audio output unplugged or at least turned all the way down, and with the transmitter turned off, locate the squelch control - you may need a screwdriver depending on which model of receiver you have. Turn the squelch control counter-clockwise until the TX light turns on, then turn it back up just past the point where it turns back off.
If you turn it all the way down and the TX light doesn't come on, that's okay. If you get blasts of noise occasionally when the transmitter is turned off, then set the squelch a little (only a little) higher until it stops.
Joe
Posted on Jul 23, 2008
seandc
  • 18 Answers
SOURCE: magic sing
hi i am working in Wow Magic sing- one of the magic sing distributor in Philippines. Is your unit wow , even if its our competitor, the manufacturer is just the same.
kindly give me more detailed information about the model and description. please be more specific.
please try to remove all song chips- if there are any...inverted and dirty song chip wont make the microphone turn ON.
check the cable and cord- open (loose connection) cord or open adaptor will not make it work as well.
Posted on Mar 09, 2009
b2ssm2n
  • 6 Answers
SOURCE: broken karaoke mic ed8000 model
Hi im joe,
if the screen says no font, no picture, no song data it means all the data installed was lost. you have to send it to the nearest service center to have it reprogram.
Posted on Mar 20, 2009
SOURCE: Magic Sing EG-18000 Microphone Delay
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Posted on Sep 17, 2009
My microphones don't connect to the base system. I have a ET 18K system from Magic Sing. When I power up the base, I get the audio and video. When I try to power up the microphones, the green lights to...
hey all, althought the manual says to hold down '0' along with the power button, which didt work.
For me it worked by holding '2' then turning on the mic (pressing the power button).
So try all the numbers.
Feb 25, 2010 | Magic Sing Along Consumer Microphone
Interference problem on my wireless magic sing, i can hear the voice of my neighbor using her own wireless magic sing on my sound system and vice-versa, it's annoying. what should i do?
The magic sing has an omnidirectional antenna which is unnecessary since you will be standing directly in front of it while using it. I recommend you take an aluminum pie plate or other aluminum piece that is larger than the antenna and place it directly behind it, perhaps even held on by tape to the antenna. You can even bend it around the antenna in the form of a V with the opening towards you, where you'll be holding the mic. This will block the other signals from your neighbor while still allow you to use it. It may even block your signals from leaking onto your neighbor's unit.
Jan 23, 2010 | Magic Sing Along Consumer Microphone
Broken karaoke mic ed8000 model
Hi im joe,
Feb 24, 2008 | Magic Sing Along Consumer Microphone
Magic sing karaoke
has anyone found a solution for this?????????????????????????????????????????????????????????????????????????????????/
my sisters stopped working... the blue light on the base goes on.. the mic lights don't work and the screen doesn't work
Sep 25, 2007 | Magic Sing Along Consumer Microphone
94 people viewed this question
 Grubhead
Grubhead
