Question about Maytag Neptune MDE6800A Electric Dryer
Maytag Neptune Model#MDE2300AYW How to lift top to reconnect a fin that came loose on one end.
I cannot lift the top to get into it to reconnect a fin that came loose on one end.I have taken the clips off the back but still cannot lift the top. What else do I have to do?
Illeagle
  • 525 Answers
SOURCE: maytag neptune electric dryer
Warning! Disconnect power before servicing!
1.Open the door and remove the screws holding the door, then pull outward on the door to disengage the hinges.
2, Remove the screws on the opposite side of the door opening.
3. Pull outward on the lower part of the front panel to disengage from the top.
4. Remove the screw from the top left and right corner top retainer bracket.
5. Rotate the retainer brackets toward each other to disengage the top from the side panels.
6. Lift top.
Posted on Jun 03, 2008
SOURCE: Maytag Atlantis Model 6400AEW Dryer bought 2003
On my 2006 Maytag Atlantis the top is held down by 4 screws 2 under the front and 2 on the back.
To remove the 2 on the front you need to remove the screws in the door and remove the door and front panel, than remove the 2 screws. The 2 screws on the back hold a white plastic fastener. After removing the screw, pry the bottom of the plastic fastener with a flat head screwdriver. Than with a very thin screwdriver or a thin pry bar wedge it under the top cover and just pop it off. Take care to not scratch your dryer while prying the plastic piece off.
Good Luck
Posted on Nov 16, 2008
tzweeb
  • 318 Answers
SOURCE: Loose Tumbler Fin In dryer
most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
Posted on Dec 31, 2008
  • 10 Answers
SOURCE: FIn inside neptune md55 dryer came loose need to remove side pane
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Posted on Mar 28, 2009
Maytag317
  • 1136 Answers
SOURCE: Loose fins
Hi, Unplug the dryer. Remove the screws on each side of the door opening. The front will pull toward you and lift off the clips at the bottom. You have the option to take the door off or leave it hang there. With the front off, you should be able to reach in and tighten the screws that hold the [addles in place. Just turn the drun by hand to get to the next paddle. You will need a 5/16" or 1/4" nut driver/socket.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 19, 2009
On Maytag dryer model # MDE9316AYA how do I get the top off? One of the fins inside the drum is loose, and I hope I can reach the screws to tighten it up by removing the top, but it won't budge and...
Opening the cabinet of these machines begins with the cabinet top. There are two spring catches located just below the cabinet top that secure it to the rest of the unit. These catches are located towards each side edge. Use a putty knife (or some other thin and flat object) to slide in under the cabinet top to disengage each of the clips. You can now lift up the cabinet top.
With the cabinet top lifted, you will see two screws located inside the top of the cabinet front. Remove each of these screws and lift the front panel to disengage the two clips found at the bottom. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
Jun 13, 2011 | Maytag Dryers
One of the dryer fins is very loose. How do I tighten it?
REMOVE SCREWS FROM DOOR HINGES AND OTHER SIDE REMOVE DOOR THE FRONT DOOR CLIP REMOVE CORNER BRACKETS LIFT UP FRONT LID AND TIGHTEN SCREWS ON FINS
Jan 25, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How do I access the drum to tighten the dryer fins
Disconnect power to the dryer !!! Remove the 2 screws holding the door hinges on and remove the 2 screws opposite the door hinges . This will let you pull the top of the front panel outward and lift off the bottom clips . If you have enough room , slide your arm thru the front opening to tighten the screws . Otherwise , remove the 2 screws holding the clips for the top , 1 on each side , and lift the top , to get better access to the screws .
Apr 10, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
One of the "fins" inside the drum has become loose. It hasn't come off, it's just loose...how can I fix it? Thank you!!
hoping it is a neptune.........
remove the screws on the door hing to cabinet
and the two opposite
lift and remove the door
once the door is off
you can pull the front panel off
grab the thin sides and twist in and pull
onvce tat panal is off you will see two 5/16 screws on each side
remove those
you should be able to lift the top
once you do you should be able to see the top of the tumbler
turn till the loose fin is on top and just tighten the screws back out and your good to go
Oct 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My neptune dryer has an interior 'fin' that is loose (mde5500ayw)
There are screws holding the fins on the outside of the drum. To get to them:
  • remove door
  • remove screws on the opposite side of the door screws (which would hold the door if it would open to the opposite side)
  • pull the top of the front panel, which was held by those screws outwards
  • remove the front panel. You'll see brackets holding the top of the dryer in place. Remove screws holding those brackets.
  • lift the top.
Good luck
Oct 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Remove and replace fins in drum
ok
1. take off the door hinge screws,
2 take off the two opposite the hinge
3. lift the door up and out
4. graqb the slim side walls on either side of the door way
turn them in and pull the whole panal tword you
5. once you have the door cowel off, you should see two top dogs screwed down with 2 5/16
romove those and the dogs
6. with the top dogs off you should be able to lift the top, like the hood of your car
7. once the top is up , you will have access to the tumbler top and the screws for the fins should be right on top
Oct 17, 2009 | Maytag Neptune MDG6800 Gas Dryer
Maytag neptune dryer has three tumbler arms and one is loose. I can see set screws but do not know how to get to them.
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below (Should be similar to yours) to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Dryers
The fin on the Neptune Dryer has come loose and I need to remove the side panel on the dryer to replace the two screws that hold one of the three fins in place. It would be simple if I knew exactly how to...
Remove the 2 screws holding the door and the 2 screws on the other side of the door opening . Pull the front panel foreward and lift off . If still not enough room to reach under to tighten , remove the 2 screws (1 on each side , holding the top down , then lift top . DISCONNECT POWER BEFORE DOING ANY WORK .
Aug 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose fins
Thanks
Vic
Jul 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE6800A Electric Dryer Logo
20 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
