Question about Hisense LCD1504 15 in. Television
I need hisense 32'' led tv remote control codes list to use astro remote control
SOURCE: Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Posted on Oct 12, 2008
  • 13433 Answers
SOURCE: hisense tv
so whats the remote you have there?
Posted on Oct 23, 2008
gopakumarg43
  • 74185 Answers
SOURCE: code remote control universal hisense LHDN32V66AUS
Hello
Four digit universal remote code for Hisnse TV are:-
0073 0182 0216
Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Posted on Mar 09, 2011
  • 11800 Answers
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Posted on Jun 04, 2011
gopakumarg43
  • 74185 Answers
SOURCE: need a universal remote control code for Hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Posted on Dec 19, 2011
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
Need code for universal Wizard 2 tv remote to operate the hisense 1080p tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Apr 07, 2016 | Hisense 40" Smart TV Full HD 1080p LED...
What is th? code for a sky remote to work a hisense smart tv
Hi Hans, Unfortunately that remote control will NOT work on a hisense television... The link below is a sky remote control codes site, Scroll down the list and HISENSE isn't on the 3 or 4 digit list. Sorry mate......
Sky Remote Codes
Apr 05, 2016 | Hisense Televison & Video
I have a brand new Hisense H3 32" tv that came w/ a bad remote. I can't turn it on so I can't use a universal remote. Hisense says no remote replacement so what do I do????
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Sep 27, 2015 | Hisense Televison & Video
Hisense tv codes for dishremote
0029,0026.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 13, 2014 | DISH Network Televison & Video
I need a code for an hisense led tv for my urc7730 remote. The manual doesn't list hisense but I thought maybe someone knows of a code that would work. Thanks
0038,0033.
Sep 09, 2014 | Televison & Video
I have a tv set make Hisense 32 inches . I bought a universal remote control RM-139ES but the 'set' key does not illuminate when I hold it. Please help me d
0281,0188,0183.
Aug 25, 2014 | BuySKU CHUNGHOP RM-139ES Universal TV...
I need a remote control code for a hisense tv
Hello
0073 0182 0216
10748
Sep 14, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
Need a universal remote control code for Hisense tv
Hello
0073 0182 0216
10748
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Hisense LCD1504 15 in. Television Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
