Question about GE JVM1460SA Microwave Oven
Emerson, model: mw1119w,not working after pressing start. A few days ago, it would self start when door closed. restart resolved it. Not warming enough few days ago.
2 Suggested Answers
  • 9 Answers
SOURCE: Microwave door not closing properly so will not work
Throw it away and get another microwave
Posted on Aug 07, 2009
Why does my emerson microwave keep running after you close the door
Possible that there is fault in the main control board as the processor seems output the drive when the door is closed and not when the start is activated. You can check the customer panel and clean the switch pad, dry if there is moisture, clean the inside of the board, use jet air to clean. If not the board could be a suspect.
Feb 11, 2013 | Emerson Microwave Ovens
MWG91155L Emerson microwave starts when the door is closed
One of the door switches is malfunctioning and must be replaced to resolve the issue.
Apr 08, 2012 | Emerson Microwave Ovens
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
Micowave new but not working
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Sep 02, 2008 | Emerson Microwave Ovens
Emerson MW8119SB microwave wont stop running with door closed
It should have a one-year warranty on parts and labor.
I'd call Emerson at 1-800-695-0098 to find your nearest authorized service center to have it fixed free.
It's probably a bad door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Emerson MW8778 Microwave Oven
Emerson MW 8700W
The fuse is usually located on the floor of the oven chassis behind the control panel, between the door switches, or near the back where the cord comes into the case.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 04, 2008 | Emerson MW8777W Microwave Oven
Blown Fuse
Apr 01, 2008 | Emerson MW8775W Microwave Oven
GE JVM1460SA Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
