Question about Eclipse CD3422 CD Player
How toreset cd key for a eclipse radio - Eclipse CD3422 CD Player
My Eclipse Car stereo has a lock code on it AVN 7000 and I bought it from a Lady she didn't know the code she never got it from her can you help me I have all my info who I brought it from.
the esn is only active if the previous owner activated it. the user would of used a CD to be a key cd and that is how they are unlocked. if the cd is lost or damaged, Eclipse can give a code to unlock it. However the original owner needs to have registered the deck with eclipse and have some kind of ID like mother maiden name. there is also a second registration that can be done. which an eclipse dealer can do, it is for used cars with eclipse radios, and things like that.
They can be real strict sometimes about giving out a code, and the authorized dealer has to be the one calling, and somtime that means a lot of time on hold.
Mar 18, 2017 | Eclipse Car Audio & Video
Radio worked, battery replaced, radio light up but does not work?
assuming it displays the message "sec"; eclipse models use a securty cd to generate an new temporary security code and let you unlock it if you have that cd it ok but if not you have to get it or get the whole module serviced at your local eclipse dealer...
Apr 25, 2016 | Mercedes-Benz S-Class Cars & Trucks
No security code audio system
These units do not have a security code like some radios. Instead, they are coded using a CD. You insert a CD into the radio and it codes to that disc. You need that same CD if you ever want to unlock the player. If you don't have it, you are SOL. Eclipse is no longer in business and they were the only ones that could reset it. The system is known as "ESN Security".
ESN Security: This unit is equipped with the Eclipse Security Network. You can register a particular music CD as a "key" device which unlocks the security. If the registered CD is not detected, the navigation and audio functions will be disabled when the main unit is disconnected from and reconnected to the vehicle's battery.
Dec 16, 2013 | Eclipse CD2000 CD Player
I had disconnected the battery on my truck. After reconnecting the battery. The eclipse avn 5435 has a screen that reads "security please insert disc". What disc? I bought this truck about a...
Eclipse radios are set up so the first cd inserted in the cd is used to unlock the radio if power is ever disconnected or the radio is stolen. You are going to have to call eclipse and see if they will unlock the radio for you. If the radio has been reported stolen, chances are they will not help you. You should be able to contact them at their website. If you can get the radio out of the dash, there is a phone number for eclipse on the chassis also.
Jul 31, 2011 | Eclipse Car Audio & Video
Won't power up. Displays SEC / Help Then SEC / 8D201399 Note the serial number is CD201399. Alan
All Eclipse brand radios have a feature called ESN (Eclipse Security Network) installed. This means a Key CD may be inserted into the head unit so that if the unit is stolen or battey is disconnected from the unit you will have to enter the key CD to unlock the unit.
For example, lets say you purchased this unit from bestbuy. You installed it in your car and you wanted to activate the ESN security feature. You need to choose anyone of your cd's from your collection, lets say you chose The Offsping, Conspiracy of One. Input the disc hit the correct buttons ( I'll explain those later) and your Eclipse 54400's ESN is active.
Now, your 54400 is stolen a week later, the thief will plug in the 54400 into his car and it will show SEC [disc], so he/she will insert a cd and it will say [ERR]. If he or she does this 5 times it will show [call 800] which will lead them to Eclipse customer service, but you will have already called eclipse and told them that your unit was stolen. Whether you get your head unit back is highly doubtful but nobody else will be able to use it.
Now for your answer, to activate ESN:
1.Turn the vehicles ignition on and press the power button 2. Press and hold Radio station preset 1 and the FM-AM button for more than one second 3. Insert the CD of your choice. A [SEC] message will now aooear on the screen and ESN is active. Anytime the unit loses power you will have to reinsert the key cd.
To deactivate the ESN feature:
1. Turn the vehicles ignition on and press the power button or the FM-AM button (make sure the tuner is on). 2. Press and hold the radio station preset button 1 and the FM-AM for more than one second. 3.Once the display flashes [disc] insert the key cd you selected to activate the ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the correct CD is inserted your display will read [---] and the cd will begin to play. If the wrong CD is inserted it will display [Err]. If you insert the wrong CD 5 times it will say [call 800] and then you have to send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio preset button 4 and the FM-AM button for more than a second and the display should show your 8 digit serial number. This number is to identify your unit if it is recovered after being stolen. Yep, that will happen!
Keep in mind that the "security code" in a radio basically fulfills this function, ensure that in case of theft, the computer does not work in another vehicle;
I didnt know there was a website to get the radio codes. Before you pay anyone to get your radio security code, I recommend you get on the internet, Eclipse dealers, ask for the parts counter, tell them you need your radio code, have your serial number handy as well as all other numbers off the radio housing.
Or, call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Hope this helps.
Oct 28, 2010 | Eclipse CD3422 CD Player
How to install cd player in my 97 eagle talon
use radio keys local radio shop might have them 2 types slots or holes in your radio
Apr 02, 2010 | 1997 Mitsubishi Eclipse
Car batter died, CD player no longer plays.
you either need to find the first cd that was played in it, or call eclipse to see if they can help you. if the radio was stolen, chances are they will not help you.
Dec 09, 2009 | Eclipse CD3422 CD Player
Eclipse cd3422 not working only shows 7AB00025
You need to enter the code or the Cd that you chose to be your key. The unit is security locked.
Aug 25, 2009 | Eclipse CD3422 CD Player
ECLIPSE CD5425 LOCK CODE
throw it in the trash no good cant reverse
Dec 23, 2007 | Eclipse CD2000 CD Player
Eclipse CD3422 CD Player Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
