Need the code for a RCA universal remote rcr804br for a norcent DVD player model no dp313
SOURCE: I am in need of the code for an Emerson DVD player
Emerson....................................1004, 1006, 1012, 1026, 1029, 1030, 1033, 1035, 1038,
Emerson................................1046, 1047, 1048, 1049, 1073, 1123, 1162, 1171, 1177, 1179, 1191
Posted on Jun 17, 2008
  • 54 Answers
SOURCE: im using the rca rcr312w
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Posted on Aug 17, 2008
SOURCE: rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Posted on Nov 15, 2008
SOURCE: need codes for universal remote model #mru 1300 by phillips magnavox in order for it to operate my magnavox dvd player model number dp100mw8
I need the codes for a sharp tv for a MAGNAVOX MRU1300/17 3-DEVICE universal remote
Posted on Aug 18, 2010
gopakumarg43
  • 74666 Answers
SOURCE: I have a Alphaline model 16987 dvd player and I need a universal remote code for a RCA - RCR804BR remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Mar 21, 2016
Need codes for konvert digital converter model SC-57 for programming by RCA universal remote model RCR804BFDR/RCR804BR
Use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Aug 06, 2016 | RCA Televison & Video
Dp313 reset password
I could find nothing on the Dp313 but according to the Dp315 you can't reset, at least not according to the manual. It says: Change Password Move the cursor to the change password item and press enter button to confirm and then input secret code "8888" (if it is first use). After confirmation, you are required to input new secret code and then press enter button to confirm. And retreat the custom setup interface.
Warning: Please remember the new secret code, otherwise you will not be able to change the parental ctrl. Please contact the agent or our company once you forget the secret code.
Jul 14, 2014 | Norcent Technologies DP313 DVD Player
Need dvd codes for rca universal remote. series RCR804BFDR/RCR804BR. got gpx dvd player
The search function of your RCA universal remote can be used to find something that will work with your GPX DVD player.
Jun 18, 2014 | Televison & Video
DVD player dp313 volume problem
try to clearn the (-v) botton ,this can be due to moisture inside the botton
Apr 26, 2012 | Norcent Technologies DP313 DVD Player
What is the 4 digit universal remote code for the norcent dvd dp315
Greetings Steve - There is no such thing as a universal remote code for any device. The remote codes are unique to different brands of universal remotes (and sometimes between models).
If you provide the make and model of your remote someone will be able to help you with the code (even easier - Most remote manufacturers maintain an up to date list of codes on their website).
Good Luck,
Mikeywaf
May 22, 2011 | Norcent Technologies DP315 DVD Player
I need codes for my universal comcast dvr remote to a norcent dvd player.
http://www.eliztech.com/remotes/rca-codes-4digit.php hope it works.... rate please
Dec 06, 2010 | RCA 3-Device Universal Remote with...
My DVD player says "wrong disc" when I insert a DVD.
with the tray open press "2812" in the remote control. The region screen will appear and then press "enter" until "9" shows as this is the multizone code
Dec 29, 2008 | Norcent Technologies DP313 DVD Player
Please I need Universal Remote Codes for DVD NORCENT DP 313, Thank you very much. My mail: livan@ispvillena.rimed.cu
Try this solution with the tray opened press V+, V-, V+, V- and your zone code will appear in the right hand corner. with the up and down toggles select your zone code of choice etc. (1,2,3,4,5,6,......255). 255 is the multizone code.
Mar 12, 2008 | Norcent Technologies DP313 DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
