My 32 in tv speakers are making cracking sound
2 Suggested Answers
SOURCE: I have a Dell TV 32 In.LCD W3201\r\
I had the same problem with my dell tv. It's the exact same one you have. It kept making noise at first, and then the sound just went out. I changed the speaker wires to a slightly stronger, thicker wire and now it works great!! I hope this works for you.
Posted on Dec 16, 2009
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
Picture but no sound
Try reset the Audio back to factory setting.not work. Take the tv aparts,check all the connections to the speakers tight,not any cracking soldering.
Jan 05, 2010 | Element Electronics FLX3210 32 in. LCD TV
Dec 05, 2009 | Dell W3201C 32 in. LCD Television
Norcent 32
Is the sound coming from the TV speakers or from an attached component?
If from the Component, use the TV speakers if it has one. If the TV speakers stay on then you have an audio component issue.
E
Mar 02, 2009 | Norcent Technologies LT-3222 32 in. LCD...
Dell 32 inch LCD Tv volume and menue problems
We also have a 32" LCD Dell flat screen tv #W3201C that has no sound. It's about 2/12 yrs old. One speaker started having a problem and we disconnected it. That was a couple weeks ago, now there is no sound at all. Dell should not be let off the hook so easily. Obviously there is a problem with the tv and it should be Dell's responsibility to make it right. Does anyone know if a class action suit has been initiated?
Mar 08, 2008 | Dell W3201C 32 in. LCD Television
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Toshiba TV 36''
  •  this cracking on my tv. It cracks and makes lots of noises
  • it sounds me that your speaker paper cone has become hard or paper has damaged. so best remedy is to change speaker.
  • if it is ok then replace all electrolytic  capacitors in audio output section.
  • check supply to ic or ic.
  • hope this will help.
Oct 11, 2007 | Toshiba CF36G40 36" TV
Televison & Video Logo
10 people viewed this question
Top Televison & Video Experts
