Question about Dryers
Kenmore smartheat quiet pak 4 dryer
Escucho un pequeno clik en la parte inferior detras y sale el codigo PF y no funciona. que puede ser ?
Master_Tech
  • 770 Answers
SOURCE: Por favor denme respuesta en Espa?ol
There is a thermal fuse on the top portion (side)of the heating element check to make sure it is not open this will not allow the unit to heat also the vent maybe clogged to the outside causing this to blow the fuse check that as well
Sorry I can read and understand Spanish but cant write it
Posted on Aug 05, 2008
huuum
  • 750 Answers
SOURCE: gas dryer
Hi Mette-q,
Welcome to fixya.com
I'm Huuum,
You said,you have a Kenmore gas dryer mod. 110.95087400 ser. ms0201135 it's a smartheat quiet pak9. Is there anyway I could convert this from natural gas to electric, is there a conversion kit available.
They do have conversion kits for gas to LP.
But I believe that there is no gas to electric.
You must find a gas line from some where in the home and run it to your location, or buy an electric dryer.
Remember that if you can run a gas dryer it will save you 30% on your energy bill over electric and in time pay for the cost of running the gas line to it.
I hope you are not in an electric only house!
How old is the dryer?? Waiting for your response!
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Here is a interesting report that I just read today
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Posted on Sep 22, 2008
cnavarro
  • 2460 Answers
SOURCE: Restriccion de llamadas en central telefonica
Intento la traducción en línea. Presione el botón de intercomunicador del teléfono y marque 790. Esto es la extensión orden clara. Espero que este ayude. Si no, por favor comente atrás.
Avíseme si usted entiende este.
Respetos.
Carl
Posted on Jan 14, 2009
  • 232 Answers
SOURCE: ZARCERO.
A lo mejor deberias leer las instrucciones de tu Pioneer. Haveces estos radios tienen settings para bajo. Si esto no te trabaja posiblemente hay un problema con tus conecciones. Estas usando el harness o solamente tape? Creo que este radio tiene salida para bajo a lo cual el woofer deberia estar conectato. Si todo esta conectado correctamente, es un problema de settings en el radio.
Posted on May 18, 2009
SOURCE: mi carro de repente se memato y ya no quiso en
mi carro plymount breezer mod.1996 motor 2.0 de cuatro cilindros de repente se paro y ya no quiso funcionar, no hay chispa hacia las bujias y la bomba de gasolina no funciona.segun me lo checaron y me comentaron que era la bobina y no fue despues que fue la computyadora pero ahorita ya estoy indeciso gracias
Posted on Jul 01, 2010
Necesito programar un control a tv insignia?
Hola Maria, sera un placer asistirle con la inforamcion que necesita. Disculpe la tardanza en responderle. Quizas en este momento ya no necesite mi ayuda pero de todas manera se la proveere por si en un futuro la necesita. Para que su control funcione con tu TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Sigua este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV (Insignia). Una vez hagas esto te aparecesaran los codigos que posiblemente funcionan con tu TV. El procedimiento a programar su control es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 720#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor o subir el volumen, deberia funcionar. Si funciona asegurese de poner el control en modo de satellite de Nuevo. Esto lo hace oprimiendo el boton de SAT en la parte de arriba de su control una vez solamente. Espero esto le ayude al no ser asi por favor envieme un correo electronico directamente a kimberly.escobar@dish.com
Kimberly Escobar Social Media Representative DISH L.L.C
Jan 16, 2013 | DISH Network IR Remote Control
Que sinigfica po442
Hola:
P0442 - Evaporative Emission Control System Leak Detected (small leak)
Lo del codigo es una falla del control de emisiones puede ser que el tapon de gasolina ya no este cerrando bien o alguna maguerita del canister se desconecto, no es nada que ocasione gran falla. Esto indica una fuga de vapor de combustible en el sistema de control de EVAP. De hecho, la filtracion puede ser de un agujero tan pequeno como 0,04" de diametro. El sistema de emision (EVAP) de control impide el escape de vapores de combustible del sistema de combustible de un vehiculo.
Los vapores del combustible son enviadas por medio de mangueras a un filtro de carbon para su almacenamiento. Mas tarde, cuando el motor esta en marcha una valvula de control de purga se abre para permitir entrada de la aspiracion para extraer los vapores de combustible en el motor.
Sintomas: Es probable que no se dara cuenta de los problemas de manejo.
Causas: Un codigo P0442 medio mas probable de uno o mas de los siguientes ha ocurrido:
Un gas suelto o colocado indebidamente el tope
Un disconforme de gas de cabeza (es decir, no de fabrica / marca original)
Una pequena fuga / agujero en una manguera de vapor de combustible / tubo
Otra fuga pequena en el sistema EVAP
Ventilacion defectuosa o-ring
Posibles soluciones: con un P0442, la reparacion mas comun es:
Retire y vuelva a instalar la tapa de la gasolina, borrar los codigos, y la unidad por un dia y ver si los codigos de volver.
De lo contrario, vuelva a colocar la tapa de gasolina, o
Inspeccione el sistema EVAP de cortes y agujeros en los tubos o mangueras
Espero que esta informacion le sea de ayuda. Suerte, y recuerde calificar esta respuesta.
Gracias por usar FixYa.
Jul 15, 2012 | 2000 Ford Explorer
BANDA DE UNOS 4 CENTIMETROS EN LA QUE SALE MAS CLARO O NO IMPRIME.
  • Puede ser que el cartucho de toner se esta quedando vacio ( en este caso sacalo de la impresora y movelo un poco hacia los costados, insertalo en la maquina), tambien fijate si el rodillo de revelacion del cartucho tiene toner en toda la superficie.
  • Otro problema puede ser que el laser no se proyecte en el tambor de imagen (para este caso chequea que nada obstruya el paso del mismo)
  • Y por ultimo el Laser, estan sucios o empañados los espejos del mismo (limpiar con un trapo seco que no deje residuos).
Sep 07, 2011 | Xerox Office Equipment & Supplies
Quisiera saber codigos para la tv vizio
Hola mi nombre es Kimberly Escobar con DISH Network, sera un placer ayudarle y proveerle la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con un televisor Vizio son los siguientes: 627, 505, y 520. el procedimiento a integrar uno de los codigos es el siguiente: oprima el boton de t.v localizado en la parte de arriba en el control por 5 segundos, una vez los botones se iluminen en rojo ingrese uno de los codigos seguido por el signo de numero. Por ejemplo 627#, el boton de t.v debera iluminarce 3 veces. Despues de este procedimiento puede intentar usar el control con la t.v. Tambien puede visitar este link, aqui puede encontrar mas codigos y los pasos a seguir para programar el control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita ayuda adicional me puede contactar directamente a kimberly.escobar@dishnetwork.com. Gracias y espero esto le sirva de ayuda.
DISH Network
Kimberly Escobar
Aug 26, 2011 | DISH Network IR Remote Control
Como puedo encontrar el codigo para mi televisor philips magnavox me podrias ayudar pls
Hola mi nombre es Kimberly Escobar con DISH Network y seria un placer ayudarle proveendole la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con su televisor marca Philips Magnavox son los siguientes: 566, 888, 560, 829 y el 656. El procedimiento a programarlos es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en el control hasta que los demas botones a la par se iluminen en rojo, una vez esto seceda ingrese uno de los codigos seguido por el signo de numero, por ejemplo: 566#. El boton de T.V deberia iluminarce rojo 3 veces. Despues de esto puede intentar usar el control con T.V no le podemos asegurar que controle totalmente todas la funciones de la T.V. Este link tambien le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara codigos para sus aparatos y el procedimiento a como programarlos. Espero esto le ayude muchas gracias y si tiene alguna pregunta me puede contactar directamente a mi correo electronico kimberly.escobar@dishnetwork.com
Feb 28, 2011 | DISH Network IR Remote Control
Compre una tarjeta y cuando entre el codigo en mi computadora para comprar games el sistema me dice que el codigo esta mal o que la tarjeta no tiene fondo que puedo hacer
Primero identifica que estas entrando el codigo correcto. Tratalo por lo menos dos veces. No trates esto mas de 10 veces porque subes el riesgo donde PSN puede cerrar tu codigo.
Si eso no funciona, asegurate que el codigo que te dieron esta activado. Para asegurarte de esto, verifica en tu recibo de la tienda que te activaron tu codigo al momento de comprarlo. Normalmente en el recibo de la tiendo debe de decir ACTIVAT FEE.
Otra opcion podria ser de simplemente esperar. Puede ser que tu codigo se cerro si lo intentaste muchas veces. Solo espera unas horas para entrarlo otra ves.
Tu ultima opcion podria ser de solamente regresar la tarjeta a la tienda a cambio de una nueva.
Gracias.
Feb 27, 2011 | Video Game Consoles & Games
Mi xsp m1330 tiene password en el bios y no me obedece para iniciar
Hi, usted puede intentar quitar la batería del Cmos del panel inferior. Usted puede ser que necesite desatornillar el panel inferior primero para revelar la batería del Cmos.
Espere que esto ayude, gracias por usar Fixya, su recomendación se aprecia altamente para la ayuda libre.
Sep 29, 2010 | Dell XPS M1330 Notebook
Zebra Stripes s400
el codigo de barras sale corrido de su posicion
Oct 29, 2008 | Zebra Stripe S400 Label Printer
No est? funcionando
El codigo H98 indica que puede haber un magnetron defectuoso, tambien que puede haber una fuente de alimentacion defectuosa o puede ser que exista un falso contacto en el connector CN702. Han habido reportes que la fuente de voltaje ha salido con poca vida y fallan a menudo.
Si habres este aparato ten cuidado con el alto voltaje que existe en un condensador de alto voltage.
Suerte.
Jan 24, 2008 | Panasonic NN-S768BA/WA Microwave Oven
Dryers Logo
Top Dryers Experts
