Question about Denon Avr-2312 Home Cinema Receiver
I have 2 volume displays showing on my TV from my AVR-2312 Receiver
2 volume displays started showing up today - one is a volume bar from -99 to 0, the new one is a bad graphic showing "AVR-2312 Volume" -99 to 0 - it's a bit off from the other volume reading - and I want to turn it off and keep the original. They both go away after 2 seconds. I was setting up Google's Chromecast today and was hitting a lot of sound settings so probably tripped something - help - searching manual for 30 minutes was no use.
SOURCE: No sound from my brand new speakers
I am assuming you have tried new speakers on used unit on both A & B choices. Have you tried your new speakers with old 2802? If they work OK with old unit, you have problem with amplifier in used unit. Take the used 2802 to a reputable shop and have it thoroughly tested. Perhaps it is just a loose connection.
Posted on Apr 02, 2007
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
SOURCE: Denon AVR-3805 zone 2 no longer working
If no sound coming through Zone 2, steps that worked are below. Layout: Denon AVR-988 running in 5.1 mode with patio speakers designated as Zone 2: 1) check that patio speaker wires are connected to Denon's back surround speaker terminals, 2) check "Menu then "Manual Setup" and scroll to check that "Amp Assign function is set to "Zone 2". You won't get Zone 2 sound unless this is chosen in this instance. Also check the volume settings in the "Manual Setup" to ensure you haven't turned sound down by -40 DB or limited it. Now try turing on Zone 2 sound either on front panel or on rear of remote. If you still have no sound, what worked for me is there's a Zone 2/Rec Out pushbutton on front left top panel by round input knob. This must be set to "Zone 2 Source" and not "Rec Out Source".to avoid diverting the signal to the Rec Out jacks. Keep turning the input select button until it reads "Zone 2 Source". Then turn on and this should route the signal to your Zone 2 speakers. srhfish
Posted on Mar 04, 2009
  • 92 Answers
SOURCE: AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
Posted on May 18, 2009
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
My t v has no volume
Do you see the volume indicator moving when you press the vol up/down?
Could the internal TV speakers have been turned off? This is done when using a sound bar or a AVR (Audio Video Receiver) aka Home theater
Mar 03, 2015 | Televison & Video
Reciever shuts off
Most likely cause of a receiver shutting off when turned up is a bad speaker or speaker wire.
As far as having to turn it up almost all the way, that is the norm on most new receivers today. Most receivers no longer have a true preamp section, which means you have to run the main amp much harder in order to get a decent sound level.
Feb 04, 2014 | Denon AVR-E400
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
I have a harman kardon avr 745....looks frozen
My device is AVR 645, but AVR 745 has the same power regulator board and you could check, if the problem is there.
(AVR 645 volume blue light was not pulsating)
When device is turned on, it shows all display indicators,
no blue light on volume button and no response to any remote or front panel buttons.
Reason for failure:
No 3.3V and 5VD voltages.
I checked bridge rectifier D701 on power regulator board.
One of the diodes was shorted. Also fuse F702 was blown.
Original D701 is KBU6G, but because regulator board is a bit difficult to get out, I decided to use KBU8G. The only difference is Amps rating 6A versus 8A.
Be sure to use SR-5-3.15A fuse to replace F702 and use heat sink paste (you know where) when board is reinstalled.
There is large heatsink in the middle of the receiver. Power regulator board is mounted on the right side of that heatsink. It is down there near the front panel and to get it out you most probably first have
to remove two PCBs hindering access to some regulator component screws. Here are pictures to clarify situation:
harman-kardon-avr-745-looks-frozen-igzigj2finjgh1nndvq1cugs-5-0.png harman-kardon-avr-745-looks-frozen-igzigj2finjgh1nndvq1cugs-5-1.png
Oct 26, 2009 | Harman Kardon AVR 140 Receiver
Volume display seems backward
This is because the volume knob on ANY stereo is actually an attenuator.  Meaning, the stereo would play at full blast (way too loud!) if left to it's own limits of power, so your volume knob is actually "dialing down" the power, or when fully turned up, letting it all flow.
The reason that the numbers change like that is it's showing you how much attenuation is happening in decibels, or dB, so for insTance, when it's at "-30" that's a pretty decent volume, but at "-5" it's much louder and your neighbors might complain.  I think you'll notice that it can be cranked to something like "+5" which on my AVR 100 will blow the speakers.
In other words, this is normal, so relax and enjoy the music!
Dec 24, 2008 | Harman Kardon AVR 5 Receiver
On screen display does not appear
Same problem, thanks for the solution -- resetting power solved it.
Mar 02, 2008 | Denon AVR-4308CI Receiver
Denon AVR-1802
might hav eto buy new control modual parts store hi end parts store order one for u
Jan 25, 2008 | Denon AVR-1802 Receiver
Denon Avr-2312 Home Cinema Receiver Logo
24 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
