Question about AEG Dryers
Simplicity humidity sensor dryer not producing heat
Not producing heat
2 Suggested Answers
  • 46362 Answers
SOURCE: how do i fix the heat on a simplicity humidity sensor dryer it has no heat at all
check the heating element and the thermal overload . possibly the door switch also .also check for lint buildup as they need to breathe to work properly
Posted on Oct 12, 2016
How do i fix the heat on a simplicity humidity sensor dryer it has no heat at all
Oct 12, 2016 | Dryers
The dryer wont heat-it over 5 hrs to dry a load. it would not turn off on automatic side & just keeps running. it turned off on the timed side
If it's not making heat the humidity sensor will never dry out, therefore it keeps running. It sounds like your heating element is bad.
Jan 20, 2014 | Whirlpool GGW9200L Gas Dryer
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
My dryer heats up ,spins but everything inside just is steamy the clothes wont dry
is your dryer vent clear everywhere to the outdoors,no kinks,lint,etc. in exhaust hose? then check the humidity sensor if equipped with one
Oct 27, 2009 | Dryers
Won't heat up and doesn't shut off
You likely need to replace the element. test the dryer in auto and timed dry cycles. If the element is gone you will have no heat in either.
If the humidity sensor is shot or the dryer vent hose is clogged , the dryer will run forever and not dry or shut off.
Check for blockage first. then run a test cycles on both settings and post back
Sep 13, 2009 | Dryers
Dryer turns on, drum rolls but no heat
the humidity indicator does not show anything and I get no heat and the end of cycle tone dings. Is it just a humidity sensor or is it more like a heating element problem. Vent is clear.
tdrecoll@comcast.net
Jun 04, 2009 | Kenmore Dryers
Dryers Logo
54 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
