Question about Body Champ Magnetic Cardio Dual Trainer
Trainer is very har to peddle at any adjustment
How to adjust cable operated clutch
Hi,if it can be adjusted it will have an adjusting nut on the arm that comes out of the gearbox bell housing where the engine joins the gearbox (if it can be manuely adjusted the peddle will try to engage when the peddle is at its lowest),but alot of cars have a ratchit on the clutch peddle so it adjusts itself,so when the clutch plate is coming to the end of its life the clutch starts ingaging when the peddle is high.hope this was some help,all the best with it.
Nov 27, 2015 | Cars & Trucks
Pecor 556i says to peddle faster
Then pedal faster.....
If you are pedalling fast enough, the battery may be low.
Jan 11, 2014 | Precor Exercise & Fitness
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
Do elliptical trainers have adjustment qualities?
Yes. Most trainers have adjustments for elevation. The elevation feature on an elliptical doesn't make the workout harder; instead it changes the emphasis so that the higher the slant, the more your glutes and hamstrings will be worked out; whereas the lower positions emphasize more on your quads and calves.
Aug 02, 2012 | Exercise & Fitness
Summit trainer peddles squeak
1) Try to LUBE according with the maintenance instruction manual, and tight any bolts+nuts loose, and replace any parts worn.
1a) Go to the troubleshooting
2) If you do not have download for free> www.fitness.manualsonline.com
or www.iconservice.com or www. retrevo.com
God bless you
Jun 10, 2012 | Life Fitness Integrity Seires Summit...
Squeaking peddles
1) Lube inmediately, and tight the bolts+nuts, and replace any parts worn.
2) Follow the instruction manual according the schedule maintenance
God bless you
Jun 10, 2012 | Life Fitness 95Li Summit Trainer Build Up...
My Kinetic trainer increases resistance when I increase speed. How can I maximize resistance at low cadence of say 60 rpm?
You can't with this type of trainer. You have to have a trainer where you can manually adjust the resistance. The closest you can do is shift your gearing.
Apr 04, 2011 | NRS Kinetic Road Machine Trainer
Red brake light stays on
Many cars have a switch that rests on the arm for the brake peddle that self adjusts. If something gets stuck between the switch and the peddle it can adjust the switch too far way from the peddle arm. When the object that got in the way falls out or is removed the switch will no longer contact the peddle arm and the brake lights will stay on. You would probably need to remove the panel cover for the bottom of the dashboard to access the brake peddle are and brake light switch. Once you see the switch depress the peddle with your hand and push the switch toward the peddle are. It shouldn't be too hard to push back into place and will probably make a series of clicks as it moves. Once the switch has been pushed in release the brake peddle and the switch will adjust itself back to where it should be.
Mar 31, 2011 | 2006 Chrysler 300
Body Champ Magnetic Cardio Dual Trainer Logo
Top Body Champ Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Body Champ Exercise and Fitnes Expert? Answer questions, earn points and help others
