Question about Sharp ELW535 Calculator
I divide numbers that dont go evenly into each other and it rounds the answer to the nearest whole number. how do i stop this?
    Scholar:
    New Friend:
  • 74 Answers
Press SETUP and and choose 1 for FSE. Then choose 3 for NORM 1. This should fix your problem.
If all else fails there is a reset button on the back of the calculator.
Posted on Nov 26, 2014
3 Suggested Answers
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
  • 8073 Answers
SOURCE: I have the sharp model
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Posted on Jan 15, 2012
What is 5.375 rounded to the nearest whole number?
5.375 rounded to the nearest whole number is five (5).
Feb 19, 2015 | Office Equipment & Supplies
Math Division
1600 divided by 24 is 66 2/3 or in decimal, 66.6666 with the 6s repeating forever. Rounded to the nearest whole number it's 67 since it's closer to 67 than to 66.
Oct 20, 2013 | Office Equipment & Supplies
How to calculate mode with caso fx-991ES
MOD simply calculates the remainder that is left over after dividing by the MOD parameter.
For example, 10MOD7 = 3 since you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg 389487MOD31 you start by dividing 389487 by 31, which gives 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD calculation has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculators working capacity.
An alternative method is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Feb 23, 2013 | Casio FX991ES Scientific Calculator
How to find remainder as a solution in CASIO fx991ES
Finding the remainder from a division calculation is often referred to as using the MOD function, though this isn't available directly on the fx-991ES.
To obtain the remainder, for example when dividing 10 by 7, you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg when dividing 389487 by 31 (equivalent to 389487MOD31) the division gives an answer of 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD or remainder calculation involving integers has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculator's working capacity.
An alternative method which avoids the rounding of the fractional part is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Dec 16, 2012 | Casio FX991ES Scientific Calculator
My ti 30 calculator always rounds to the nearest number with the answer. How can i get this to stop????
To stop the calcultor rounding your answers to the nearest INTEGER, press [2nd][FIX] followed by a number other than 0. For exemple
[2nd][FIX] 3 will display the numbers with 3 decimal digits.
Hope it helps.
Thank you for using FixYa.
Nov 24, 2009 | Texas Instruments TI-30XA Calculator
VB 6.0 ROUNDING A NUMBER
Use the Math.Round() function. It takes two arguments, the first is your number or a variable holding your number and the second is the number of decimal places. This will only round to fractions of a whole number though and you need to round to the nearest 10. So divide your number by 10 before you round to shift the decimal place once to the left and multiply by 10 again afterwards to shift it back again.
answer = Math.Round(32.1 / 10, 0) * 10
Apr 02, 2009 | Microsoft Visual Basic 6.0 for PC
Sharp ELW535 Calculator Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
