How do I download data recovery program in the hp 2000 2b19Wm
I have accidentally formatted my partition drive f
Deleting or formatting won't make the data in computer hard drive erased permanently.
Those deleted data is still stored on the computer hard drive , it's just invisible or inaccessible. Only the FAT or NFTS table is erased (the information about where those data were saved), but the real data are still intact there in sectors of the hard drive.
So as long as those data are not overwritten by new data, it's highly possible to recover them. And the MOST Effective way is to rely on some format recovery programs.
Try asoftech data recovery program, which can recover data after deeply scanning your computer hard drive to look for lost data you accidentally deleted or formatted. download the software from link below
Format Recovery Software
You may refer to this tutorial for detail step by step info
how to recover files after reformat
Jul 27, 2012 | HP Computers & Internet
How can I reset my hp compaq desktop
What do you mean reset? Are you talking about System Restore or System Recovery?
Get onlineand got to www.google.com In the google search box type: "HPSupport" or "Compaq Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and documents.
Apr 26, 2012 | HP Computers & Internet
I want to recover which i lost from my memory card
A memory card recovery program will be the best choice. I had success with this file recovery program called asoftech data recovery, which is very easy to use and worked well for me. You may download and have a try. here's the download link
http://www.asoftech.com/data-recovery-software-download.html
Oct 30, 2011 | Nokia 3110 Cellular Phone
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I cannot see my picture folder in my hp cb350 camera to download the pictures. i think it's because of my free avira av detected the camera for virus. is there any way to recover my pictures in the...
Firstly, you should use virus remove program to get rid of virus and then try to use data recovery program like Card Data Recovery, a professional memory card recovery tool to recover lost pictures.
Sep 19, 2011 | HP CB350 Digital Camera
Once i booted my laptop i got msg as some windows file missing. I recovered using hp recovery. When i restarted it said the same error. From then on it started saying "drivelocked hdd bay password...
You can recover data from hard drive with data recovery software.Then format the drive toget it fixed.
For data recovery program,here are two of the best Iused.
For Windows: http://www.any-data-recovery.com/index.htm
For Mac: http://www.stellarinfo.com/mac-data-recovery.htm
You can download one of them and scan your hard drive for free to previewwhether your files can be recovered. They will show you the file name, type, dateand of your files and thumbnails for your pictures that it found on yourdrive.
Sep 15, 2011 | HP Compaq nx6310 Notebook
Want to install my 2tb hp external hdd not recognized lights up beeps when connected but nothing...have a 1tb hp that is fill to the brim tha twas assigned drive j:...but when trying to connect this new...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program called asoftech data recovery to recover your files. you can find it from facebook
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 05, 2011 | HEWLETT-PACKARD 2TB 3G SATA 72K 35in MDL...
My compaq nx9010 states that my operating system is not found, I don't have any discs for it. it also keep rebooting itself as it has a virus but i can't get in to sort it out. it always reboots from the...
Reinstall the system and it will be OK.Then use a data recovery program to get your files back.
It is easy to recover the files.
Download this program called Tenorshare Data Recovery and run it.There are four steps to do:
1. Select deleted recovery. It will take you a few minutes to scan your note book;
2.You can see all files listed on the task window, click the files you want to recover;
3. Select a path folder for the recovered files to save in;
4. Click "OK" to finish recovery.
You can get the program here:
http://www.any-data-recovery.com/product/index.htm
Mar 31, 2011 | HP Compaq nx9010
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
