Question about Dishwashers
Kitchenaid wiring diagram dishwasher model kudso1flss2
Kitchenaid kuds01flss2 wont turn on
3 Suggested Answers
SOURCE: I have a kitchenaid superba
After taking the bottom cover off, I noticed that it's the cheap string that's broken and not the spring. I'm assumming that's pretty easy to replace? I've ordered the parts and just waiting. Any tips on replacing it would be appreciated.
Posted on Jun 10, 2008
ginko
  • 19396 Answers
SOURCE: I have a kitchenaid KUDS01FLss2
Hi.
The appliance is in lock mode.
Try first disconnecting power by tripping circuit breaker or disconnecting power cord for two minutes.
After that the appliance may still be locked, at that point you will need to reset the dishwasher control module.
The control module is reset by pressing a key combination of keys.
Combination is:
  1. HI-Temp Wash
  2. Heated Dr
  3. Hi-Temp Wash
  4. Heated Dry
  5. Hi-Temp Wash
  6. Heated Dry
This model does not have heated dry, and the combination uses Energy Saver button instead:
  1. HI-Temp Wash
  2. Energy Saver Dry
  3. Hi-Temp Wash
  4. Energy Saver Dry
  5. Hi-Temp Wash
  6. Energy Saver Dry
Press the button in rapid sequence without big pauses, or it will not work (it is often called button dance).
Regards.
Ginko.
Posted on Nov 16, 2010
Upper dishes not clean on KUDS01FLSS2
Hi there, I had the same problem recently and instead of calling a repairman, I found these step by step instructions with photos on the web. Easy to follow and will save you $. http://en.wikibooks.org/wiki/How_To_Repair_Dishwashers/KitchenAid_Repair/Chopper_Replacement
Apr 20, 2013 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid kud124se diswasher manual
The owners manual can be found at http://www.manualslib.com/manual/722766/Kitchenaid-Kud124se.html#manual. If you remove the bottom panel there is a service diagram tucked in a plastic sleeve that is affixed to the back of the panel (the L shaped panel, not the flat one).
Oct 03, 2012 | Dishwashers
Kitchenaid dishwasher model KUDW03CTBL2 arms do not turn
There is a blockage in the wash pump area which is preventing the water from reaching the wash arms.
The problem could be the chopper unit (item 6) in this diagram. You will have to open the assembly according to the diagram and locate the blockage.
Hope this helps.
Jun 01, 2011 | KitchenAid Dishwashers
My Kitchenaid model KURD25SHBL0 dishwasher is not draining. Drain line is clear, wash cycle runs fine, and there is no obstruction to overfill sensor. Can hear pump runnng during drain cycle but no...
Usually the wiring won't affect the direction of the pump turn. It is more likely that the fins on the drain pump empellar are damaged.
May 30, 2011 | Dishwashers
Recently my dishwasher KUDSO1FLSS2 is not cleaning the top rack very well requiring multiple washings. Both the top spinner and mid rack spinner (under top rack) turn freely by hand but limited water...
If there afilter on the inlet hose it might need clening,if you have a partial blockage it will reduce the volume of water entering your appliance.Hope this helps.
May 14, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
The unit fills and pumps out OK. However, the wash arm does not shoot water or rotate. The unit model is listed as KUDSo1FLSS2 and the serial number is FP4117644.
IT NEEDS TO BE CLEAN THE ROTATION IS CAUSED BY THE WATER PRESSURE. THAT STOPS WHEN ITS CLOGGED WITH BUILDUP... YOU CAN GET A MANUAL THAT HAS THE INSTRUCTIONS AT TVPARTSANDMANUALS.COM
Jan 12, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
I have a Kitchenaid dishwasher model KUDS01FLSS2. I finished replacing the door balancer cord and started the dw up and it started leaking underneath from the bottom somewhere around the middle of the...
In this Kitchenaid dishwasher model KUDS01FLSS2, the whole motor and water pump assembly simply sits (I think loose) in the bottom of the DW. From the inside, it is the round mechanism where the sprayer is mounted above the chopper, all one piece sitting in (or mounted with) a large rubber washer around it. Somehow this assembly had lifted up slightly on one side which allowed the water to just poor through the bottom floor of the DW. I simply pressed down on the whole mechanism positioning back in its proper place. It did not take much pressure at all to position it back into its place. This stopped the leak and is working like a charm.
Nov 13, 2009 | KitchenAid Dishwashers
Trying to access the pump and motor section
You should check the thermal fuse problem listed elsewhere on this site. My power went out on mine, and it was a cheap {less than $20 part} that snaps into the control panel. It eventually blew again a month later, and I replaced the heater element, and the new heater element came with a new board that was very easy to install. the new programming on the board actually speeds up the cycle due to a higher wattage heating element.
But what I didn't do the first time was replace the wires going to the thermal fuse that came with the replacement kit. (Apparently the OEM wires are too thin) Had I done that, I probably never would have tripped the fuse again and not bought the new heater element.
Jan 08, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid not cycling
DONT KNOW THIS UNIT BUT TRACE BACK YOUR STEPS. CHECK THE PRESSURE SWITCH FOR AN AIR BUBBLE AS THERE SHOULD BE NO ACTION WITH THE ROTORS UNTILL YOUR WATER LEVEL IS CORRECT.CHECK IF THE SUMP LIMIT ISNT STICKING.
Aug 22, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
