Question about HP OfficeJet 7410 All-In-One InkJet Printer
Error message i can't seem to send a fax. I get an error message that reads: "Error 388" Help, please
  • belmic Dec 03, 2007
    i have get this error wen i want to send a fax with my Hp V40
  • Anonymous Sep 01, 2008
    changed phone line from wall to fax machine
  • 72 Answers
There seems to be a static on the telephone line, Please get in touch with telephone company.
Regards,
Lalit
Posted on Sep 09, 2008
  • 16 Answers
Try to send the fax at a different time when telephone line conditions have improved.
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Posted on Jan 05, 2008
Error meassage while trying to fax
please refresh fax memory and send the fax
Mar 09, 2012 | HP Officejet 5610 All-In-One InkJet...
Problem faxing-error message
Error 388:
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
When trying to fax connects ok but comes back failed error 388
A list of HP aio error codes:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You could try running the Fax test. Press setup > Tool> Run Fax test.
This will give you instructions about what you need to check and what you need to do if it failed on some of the tests.
Then try to send a fax to the HP fax test server detailed below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259105&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jan 19, 2009 | HP Photosmart 2410 All-In-One InkJet...
Fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Sending faxes
Error 388 is for telephone line conditions being bad, have you called your telephone company and head you telephone line checked...?
If not please have it checked.
For more details on the error message check the link bellow with Error codes any their reasons:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=79477
Good Luck
Oct 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax not working Error 388
We had the exact same problem. Static on the line. We had the cable company check and sure enough our digital modem for the phone line was bad. The new replacement fixed the problem instantly.
Aug 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Fax
error code 388 says :-
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
Mar 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
153 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
