Question about Nikon 2 Sets Of Nikonos Sb 105 Strobes
SB105 connector broken
2 of the 5 wire connections inside the SB 105 port are broken and strobe connection cord will not wokr
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Nikon Expert
  • 305 Answers
Yes you are right when broken it does not work properly
Posted on Feb 01, 2015
2 Suggested Answers
  • 685 Answers
SOURCE: sb 105 fires when I advance the film, not when I
Send that back to Nikon for service. http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Posted on Nov 08, 2009
On my portable ac model number wa1230e the inside where the ac wire is connected got disconnected some how where do i connect it back up
The wires connect to the power switch. Usually with slip on connectors. If the wires are broken you may be able to put new connectors on them if you have the tools to do so, otherwise a complete replacement cord is needed.
Aug 08, 2015 | Heating & Cooling
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 3030 All-In-One Printer
My dell inspiron 1420 wont charge without a lot of jiggling and moving the power cord around. i think it is the actual power whole inside the laptop. how do i fix this?
you are right, there is a partial contact inside the motherboard power pack. you will need an expert to do it for you, but if you are sure you can do it, just try opening the computer system and go straight to the port where the power cord is been plugged you will need a soldering iron and a lead to work on the board, around the port connector, you will see some broken soldering, all you need to do is to resolder the broken lead connection.
Oct 07, 2010 | Computers & Internet
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
Shaver keeps shorting out. It goes on and off. Hard to shave like that. ;)
If your model is run directly from the cord, you may have a broken wire in the cord. Could also be a loose solder joint where the AC port connects to th circuit board.
If you shaver is rechargeable, you probably have a loose connection inside. Look at the battery terminals and the connection from motor to circuit board for loose connection.
If you find that you need a new cord, you will find one at shaveroutlet.com
Jan 11, 2010 | Wahl Health & Beauty
I am connecting a dryer cord to a kenmore dryer. There are three connections on the junction in the back and three leads on my cord, but the only two of the junction connections have nuts allowing a...
The terminal block on the dryer , should have 3 connection spots . A red , black , and middle , white . the cord connects the outer wire red , middle wire , white , and the outer wire to black , If only 2 connectors on the block , sounds like you need to replace the terminal block on the dryer . Probably broken . Feel up inside for a black wire not attached to anything ,
Aug 28, 2009 | Kenmore Dryers
My Hayward Colorlogic pool light is flashing like a strobe light
That particular swimming pool light has a power-cycle feature that allows you to change the way your light illuminates your pool simply by turning it off and on. A strobe like effect is one of these power cycles. To change it, simply turn the switch off and then turn it back on within 10 seconds. It should reset to another cycle. It is is left off over 60 seconds, it resets to the first cycle, which could be the strobe. If cycling doesn't solve the problem, your bulb has probably malfunctioned and you are going to have to have a repair tech service it.
Jun 16, 2009 | Hayward 12v LED Color Logic Pool Light...
Nikonos V underwater camera w/ strobe
It sounds like you'll need professional service. Even slight moisture damage can foul up the shutter or the wiring that runs from the camera to the inside of the connection port. You can remove the access plate (4 screws) above the film chamber. The 5 wires below the rewind knob (blue,yellow,purple,green,black) lead to that connector. I would also check the shutter functions on M90. See if it opens.
Sep 30, 2008 | Nikonos V 35mm Point and Shoot Camera
Nikon 2 Sets Of Nikonos Sb 105 Strobes Logo
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
