Question about Avaya 1616 IP Telephone 700415565, 700450190
Avaya 1616 never show outgoing number when i press call log
2 Suggested Answers
SOURCE: Avaya 1616 IP phone doesn't
bad router means that you assigned an IP in the router section, that can not be found on teh network.
You dont have a DHCP server on the network?
Posted on Sep 16, 2011
How do you change the primary number on avaya 4406d phone
Go to the telephone switch
A. Log in
B. Do a change station
C.On the form Put your number in press enter
D.On that form change the primary preference to any button you want it to be.
Jun 11, 2014 | Avaya Merlin Magix 4406D+ Corded Phone
Avaya 1616 IP phone doesn't take the router IP when assigned statically. There is no DHCP. It shows Bad router after the phone gets a restart.
Sep 13, 2011 | Avaya 1616 IP Phone
Using AVAYA IPO 500 R6 V2 IN 1616 and 1608
Check the IPO software is installed correctly and see if the most up to date software is installed, current software version 6.1 for this model.
Uninstall previous version or current version. Then Reinstall the newest version.(6.1)
Should take of any problems you are having with the phone. Since you have replaced it once, the problem lies in the software not hardware.
Mar 16, 2011 | Avaya 1616 IP Phone
I need to change the outgoing message
Log into the mailbox and change it via option 3, change recording.
May 28, 2010 | Avaya Lucent Partner 616 Phone
Placing a Forward Button on 1616 IP Phone
What you need to do is, set up a button that will turn forwarding on. then set a number in manager on the forwarding tab, set the number. If the number is going to change a lot, then you should set a second button up as, forward number. One changes or sets the number, and the other toggles forwarding on and off
Sep 04, 2009 | Avaya Computers & Internet
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Programing Ayava partner - 18d Phone
This will need to be done at Extension 10 or 11.
Press Feature 00
Press LEFT intercom, LEFT intercom
Press right intercom. Display will ask for an extension number.
Enter the extension number you want to modify.
Now it should say "program ExtXX"
Press * * (STAR STAR)
then touch the lines in the order you want to pick them up, when finished entering the order....
PRESS * * (STAR STAR)
Then Press Feature 00 to exit programming.
Apr 30, 2009 | Avaya Corded Phone avaparp18d
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
Rerecord the outgoing announcement
Hi, Press feature 9 8 3, display shows: Log: QUIT RETRY OK, enter system coordinator mailbox and password ( default is 102 0000 ), press OK, display shows: Admin MBOX AA OTHR, Press AA, display shows: Auto Atdt Admin GRTG TABLE LINES, Press GRTG, display shows: Greeting Admin GRTG AA, press GRTG, DISPLAY SHOWS: Greeting: RETRY OK, enter greeting number ( 1 to 20, usually 1 is the Main Greeting ), press OK, display shows: Greeting < X >, RETRY PLAY REC, press REC, at the sound of the tone record your greeting, press OK to end recording, display shows: Accept greeting? RETRY PLAY OK, press OK when you are satisfied. Good Luck
Aug 16, 2008 | NorStar M7324 Telephone
Avaya 1616 IP Telephone 700415565, 700450190 Logo
24 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
