Question about Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range
Oven do not get hot enough - Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range
  • Anonymous Sep 14, 2008
    oven does not get hot nor stay at proper temperture
  • raziel_1957 Sep 14, 2008
    the oven takes a long time to obtain designated temperture
    Sergeant:
  • 415 Answers
Could be a thermostat or the element.
Posted on Sep 13, 2008
Single element stove oven, doesn't get hot enough
Your oven probably has a feature called a hidden bake element. The element is located beneath the floor of the oven. (Because of this, NEVER put aluminum foil on the bottom of the oven because it will get hot enough to melt the aluminum foil and make it bond to the bottom of your oven.) You can adjust the temperature of your oven through the electronic oven controls. Check your owner's manual for how to do this.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 08, 2014 | Kenmore Kitchen Ranges
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
The main oven gets warm but nowhere near hot enough to cook anything. Could it be the element? And if I replace it myself, what is the pen like object attached to a wire at the rear of the oven? Many...
if it gets hot but not hot enough its proberly your thermostat and the pen like thing over the wire is just a cover to insolate the bear spade connection
Aug 11, 2011 | Zanussi ZHQ575 Electric Double Oven
My Amanda gas oven Model no. AGS781WW is not heating up in the oven, nor does the broiler come on. The electronic ignition glows, I don't smell any gas in the oven. The cooktop comes on fine.
even if the ignitor glows it may not be getting hot enough to light the gas. if it does not get hot enough the gas valve should not open. try changing the ignitor, usually 30 - 60 dollars.
Jun 21, 2010 | Ovens
My bosch oven grill element is not working and my oven does not seem to be getting as hot as it should. any ideas what it could be.
More than likely the grill element has failed, and this could account for the oven not getting hot enough, as on some makes, the grill element is on at the same time as the oven element, so if the element has failed, then it will not be hot enough.
My advice would be fit a new grill element, and this hopefully will solve the problem of the oven not being hot enough.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Bosch HBN 430560B / 430520B Single Oven
Oven does not get hot enough to bake ,the broiler and bake elements get hot,but not hot enough to broil or bake items.Is it my elements or my control switches from this early 60`s oven/range ?
Probably a failure to get 240 volts to those elements.
If burners work, then it's probably an oven CONTROL(S)l failure. Test them if you know how. Very difficult to find parts for a stove that old.
Sep 19, 2009 | Kitchen Ranges
Oven takes a long time to heat up
your ignitor could be going out. the ignitor has to get hot enough in order for the gas to turn on and heat your oven. if your ignitor is going out, sometimes it doesn't glow hot enough for the gas to turn on, or it could be that is takes longer than normal to get hot enough to turn the gas on. I would replace the ignitor and that should solve the problem. Joe
Nov 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven
the igniter is not getting hot enough. It can get hot enough to allow gas to flow but not quite enough to ignite the gas. It is an easy fix. The igniter is usually under the floor of the oven.
Aug 27, 2008 | DCS RGS-305 Professional Gas Kitchen Range
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Microwave Keypad Is Hot
check blower fan, and maintained gap between oven and wall at last 2 feets. some heat comes to pad very heat may be some prolem. check every thing and reply me.
Aug 21, 2007 | Emerson MW8108P Microwave Oven
Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range Logo
172 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
