Question about Food Mixers
I have a hobart 4642 mixer grinder that s leaking oil Need help with diagnosing
    Scholar:
  • 109 Answers
Can you confirm the model number and where the oil is leaking from?
Hobart make a 4246 and a 4632, but I am not familiar with a 4642
Posted on Mar 23, 2014
bigg t
  • 640 Answers
SOURCE: how do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Posted on Dec 25, 2007
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
  • 10 Answers
SOURCE: Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
Posted on May 25, 2010
  • 44 Answers
SOURCE: Oil (or maybe broken down grease) leaking from the
You're right, it's broken down grease. The A200 doesn't have a rubber seal to prevent this from leaking, either. That's normally OK, when the grease in reasonable condition, but when it breaks down bad enough, you see what you're seeing. The grease needs to be changed which requires disassembly of the transmission. It's quite a job (and very messy) if you're not familiar with it, but if you're interested I know I've read (and may have written one) instructions on disassembling the transmission on this website. If you decide to do the job yourself, be sure to remove the attachment hub (comes out to the inside of the transmission) and clean the passage well.
Posted on Jun 10, 2010
  • 119 Answers
SOURCE: what kind of oil need to use for oil change
H600 uses Mobilgear 634.
Posted on Jul 19, 2010
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Jan 23, 2013 | Hobart 4346 Meat Grinder Mixer Chopper...
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
Hobart mixer SE401
I have an Hobart mixer se401 oil is leaking what part do I need?
Mar 20, 2012 | Hobart A200 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
Oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Aug 27, 2009 | Hobart D300 Stand Mixer
Hobart mixers A120 & A120T.. has an oil leak. Need Seal kit/repair parts info and type of oil to replace.
You need to take the old grease out and replace it with new and then replace the oil seal
by the way it is messsssssy
Jul 17, 2009 | Hobart A200 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Hobart h600 60qt mixer leak oil
call me. 626-579-3580. Ill fix it.
Mar 25, 2008 | Hobart HL600 Legacy Stand Mixer
Food Mixers Logo
147 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
