Question about HP LaserJet 2840 Printer
Wont feed from tray 1 - HP LaserJet 2840 Printer
3 Suggested Answers
POCBM
  • 121 Answers
SOURCE: paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Posted on Mar 04, 2009
  • 38 Answers
SOURCE: My printer wont allow us to print from trays 2 or
check the paper menu for tray 1 setting, it should be set to cassette. then make sure the paper size and type for trays 2 & 3 are set correctly.
Posted on Jun 16, 2010
The printer recognizes tray 2 but it will not print to tray 2.
The printer will not print from any tray if tray one is pulled out. the paper path from any other tray still goes through tray 1\'s feed path (little slit in the front of the tray). if tray one is not in the printer it will not pull from any other lower tray.
Jun 03, 2014 | Lexmark T630 Laser Printer
Tray 1 doesn't feed while tray 2 has paper, after I empty the paper from tray 2, tray 1 work fine.
if you setup tray 1 any type, any size and tray 2 to plain, and letter size, it will allow you to use tray 2 for your plain letter jobs but will pull from the manual feed tray first only if the paper is in the manual feed tray if this makes any sense to you... please mark this as a fixya...
Nov 24, 2013 | HP LaserJet P4015N Printer
Where is the manual feed
I think, there is None.
You have only tray 1 so manual feed must also be done using tray 1 by taking out all the other papers
If that is too inconvenient, get the optional tray 2. Fill that with paper and leave tray 1 for manual feed
Nov 02, 2013 | HP Officejet Pro 8600
Feeds ok from tray 1 but not tray 2 which is 11x17. There are slight buffed marks at on the papaer in 4 spots but paper wont advance. marks are about 1/4 inch long
those marks are the rollers trying to move the paper. check to see if your tray 2 is lifting.if it is then replace the feed rollers.
Sep 28, 2009 | HP LaserJet 4mv Printer
Is the Paper Feed Kit 1 a replacement paper tray?
The paper feed kit 1 is a new feed roller and a new sep. pad to install in the paper tray.
Aug 11, 2009 | Office Equipment & Supplies
Paper feed
Hope this helps
Jan 21, 2009 | HP LaserJet 5si Printer
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
HP LaserJet 2840 Printer Logo
16 people viewed this question
Ben Johnson
