Question about Makita G3500r G3501r Generator Repair Manual
STARTS BUT STOPS
STARTS ON CHOKE, THEN ON RUN AND LASTS 3SECONDSAND DIES.
Will run only with choke on
This is fuel starvation ( it is running too lean ) if it has been stood from last year with the same fuel in , the fuel may have gone stale and bloced the jet in the carb, keep priming and starting this may eventualy clear the carb, if not the carb will have to come off and clean through, ley us know if you need help servicing the carb.
Nov 25, 2012 | Garden
Yamaha tdr 125 1993 starts on choke dies with throttle
Do yourself a favor... take it to a QUALIFIED Professional and get the carb cleaned and set..,
,,. this should fix your scooter...!!
Aug 07, 2017 | Motorcycles
Husqu51 starts once but dies then just turns over
take off the muffler and try it if ok then open it up and clean the carbon from the screen
Apr 02, 2012 | Garden
I have a 1994 cadillac eldorado. Sometimes when I start my vehicle and begin to drive; it starts to shake. When I get past 10mph the shaking stops, but when I conduct a complete stop; the vehicle starts...
You need to check the choke on the engine for cold starts it chokes off air to the fuel mix . if it is closed to much the engine will want to die and shake. When the car warms up the choke opens and the car gets air and runs fine although the choke could just be part open. It still will need adjusting.
Hope this helps
Mike
Jan 27, 2018 | 1994 Cadillac Eldorado
Starts and runs like **** then dies
filter maybe very dirty, you may need a new spark plug, you're carberator may have just a spec of debris in it , all things that happened to us also, this man is a wizard with small engines..www.belgiumsmallengine.com
Apr 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My troybuilt yard pony riding lawnmower will start with the choke fully open and then dies immediatly when you take the choke off. It will only start and run with the choke fully open, but dies after 20-30...
Do you mean that you can start it normally using the choke (that would be choke CLOSED), but then it dies immediately when you move it to run (that would be choke OPEN)? And if you leave the choke in the starting position that it dies after 20-30 seconds?----- If I have that all right, then you definitely have a restriction in the gas supply. Drain all of the gas from the mower and don't use any old gas. If you have any more old gas (from last season) don't use it. If this mower has a gas filter, replace it. Put just a little fresh gas in the tank plus a little of the cleaner. Start it up, do that a few times if needed. Use a fuel additive such as Sea Foam to keep the gas from gumming up so fast.
Mar 15, 2010 | Troy-Bilt Garden
Last time I STARTED MY VSTAR 1100 I CHOKED IT FOR 10 SECONDS ON HIGH THEN MOVED TO MEDIUM CHOKE FOR 4 THEN TOOK OFF AT NO CHOKE. 2 WEEKS LATER. I started up bike Choke on high bike barely wanted to idle...
Sounds like your flooding it out with the choke out. Try the next time you go to start the bike when it's cold with the choke out and when it starts push the choke all the way in and keep it running with the throtle. If it runs better after doing this then your flooding it on start up. Use 1/2 choke to start cold and see what it does. Good Luck
Sep 29, 2009 | 2001 Yamaha V Star Classic
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
Makita G3500r G3501r Generator Repair Manual Logo
43 people viewed this question
Top Makita Electrical Supplies Experts
Craig Butler
Craig Butler
obsteiner
Tom Chichester
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
