Busted strf 6656 & zenner diode (D826 & D825) I dont know the Value of Zenner diode.
I want to know the value of zenner diode
SOURCE: Hitachi C29-F300b television
Thanks Larry I'm just a little reluctant to buy a manual to find one part in a TV repair for an elderly neighbor. Its a love job and proved more costly than I anticipated. I'll try everything I can to verify the part type first. The diode is about 30 cents US but I need to be sure of its type before I switch it on. I am very confident I have solved the problems in this set once I have the new diode in. good to hear from you and thanks for the input Regards from Rod
Posted on Aug 17, 2007
  • 2336 Answers
SOURCE: Burned out rister-r657 and diode--d637
I could find a place to get a free download.
Check HERE but you have to pay for a download.
Or you can check this site for complete assemblies for your TV.
Posted on Mar 13, 2008
  • 1340 Answers
SOURCE: I have Sharp 20V-L80M, Power
I have tried numerous times and the TV manufacturers will not sell parts or diagrams to consumers.You have to be a repair shop with a username and password just to view the stuff.Here is one possibility.
http://www.eserviceinfo.com/most_wanted_link.php?what=list&requestid=44394
I will try for others...hang on please.Here is another possibility.All I usually find is user's manuals which are free few and far between.Schematics just aren't out there.
http://esupport.sharp-cee.com/html/om/index.php?ProdLine=40&TemplateLang=en
Sorry to have to tell you that.I like to fix my own stuff too.There is nothing more I can suggest with all the limited access.Good luck!Maybe if you take the regulator out and ask a shop?
Posted on Aug 02, 2010
eagle338
  • 4889 Answers
SOURCE: I have 02 plasma
The fault lies in the energy sustain boards, also called sustain boards. X-sus and Y-sus/Z-sus are the to sustain boards. If your meter has capacitance measurement capability, test the caps to see if any of them are fried. Should read OL or infinite if its bad. Try it and let me know.
Posted on Aug 24, 2010
SOURCE: elllo iv got a lg
Not sure if it is a power supply issue for sure, but I've had a similar issue on an older model LG LCD TV. My symptoms were: in the middle of watching TV the screen blinked a magenta color for a moment and then the screen went blank, the TV would seem to turn off and on but could not get the screen to show anything, my power light would also blink 13-16 times and was delayed when turning off. after researching this forum I found a fix. Mine was a problem with a damaged capacitor on the power board it was a Samxon 2200UF 20V capacitor that had a slight bulge on the top. If you remove the back panel of your TV and locate the Power Board (the circuit board that the power cord plugs into) check and see if any of the capacitors on this board have any bulges at all they may appear very slight but will be on the top. If you you find any with bulges they are most likely defective. Remove the circuit board and de-solder the damaged capacitors with a soldering iron from the bottom of the board, and replace with a 2200UF capacitor (or whatever UF value is associated with the damaged capacitor) with a higher voltage rating of 25V or higher that way they will run cooler. Be sure to note how the original capacitors were put in (which side the negative connects to) to avoid damaging the new capacitors. I was able to find the capactitors at a local electronic store, but you could also find them online. The capacitors are $2-4 dollars each and a soldering Iron is approximately $10 at a local radio shack. This fixed my TV, cost me $12 with a soldering Iron and took approximately 1 hour to repair. If you do not see any damaged capacitors then it may be another issue, but it is a simple process to check, Again I did not perform this on the same model TV, but it was a similar symptom and an LG. Good luck!
Posted on Mar 26, 2011
What the voltage value of zener diodes? (D825, D826 red,red,gray) and D823 (red,yellow).
This table is the information used by MOST diode manufacturers that use color banding on diodes. Most manufacturers stamp the ID right on the diode but some do use color banding as the method of identification. For purposes of alignment, the side with any color band closest to either side of the diode is the equivalent of the left side of this table. The three examples in the table when associated with the values in the lower table, are identified as 1N64E for the top diode, 1N452G for the middle diode and 1N4762 for the bottom diode.
See the color coding
25789975-o5icj23xic0ud0c1fg3qznri-3-0.jpg http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Panasonic Televison & Video
Please help about the two diodes with color red, red, gray located in power supply unit. The IC switching voltage regulator is STR F6656.What is this diode? It is Zener?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Power supply circuit diagram using STRF6656 is given. There are many TVs using this circuit in the SMPS. You can get details there. Type in the STR number; in the search box at the top right of the display window; to get gathered related posts.
Jul 17, 2015 | Televison & Video
What the real value of D825 and D826 diodes?
Circuit diagrams to many popular brand TVs and other devices are given. Hope that the site will help you to point out the details of the diode.
What to do no power on 21" sony Trinitron 1997 ?
first check main card and then check fuse .if fuse is blown put new one amp fuse.af set is ok leave it .if not work then chcck seitching transister and S.T.R 6007and oo120volt zenner diode.
Sep 19, 2014 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I have a panasonic tv model 21fx20- shut off after few minutes
Request the schematic diagram directly from Panasonic.
Jun 19, 2017 | Panasonic Televison & Video
I have sympnonic 27in tv that wont turn on all i hear is a noise like its trying to turn on but nothing happens
YES. THE 19V OR 27V ZENNER DIODE IN THE POWER SUPPLY OR THE HORIZONTAL OUTPUT TRANSISTOR SHORTED. REPLACE THE PARTS.
Dec 27, 2009 | Symphonic ST419E TV
Exact value of zener diodes D826,D827 panasonic tc-21gf30
its stamp on the side in tiny print
standerd values are 3.3 volt 5.1 12.0 ...
if it broke and is unreadable
you need to know the part location on
the board D or Z then #
Jun 28, 2009 | Panasonic TC-29FJ20 TV
The charge light is not on when charging the phone
i have the same problem, but the handset dont charge. u have to change a zenner diode, inside of the base.
Nov 08, 2008 | GE 27831 Cordless Phone
The unit light doesnt light up, is it broken
you have to change a zenner diode inside of the base unit.
Jun 19, 2008 | GE 27831 Cordless Phone
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
