Whats the best beacon interval to set on westell modem?
2 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: westel 327 modem setup
it is toon complicated to explain how every thing should go together and how th moderm should be setup. IP address and the cryption for the wirless.
I am go ing send you the website with the quick setup guide.
if you need step-by-step instruction let me know, i will try my best to describe it to you.
let me know if you have other question that you need answer.
frcs68@hotmail.com
Posted on Oct 20, 2008
I cant find my beacon interval
Select Wireless under the Configuration tab, then select Advanced from the side menu the beacon setting should be the 3rd setting listed.
The default beacon setting should be good for any setup it might help to know why you want it changed.
Jan 30, 2013 | NetGear N600 Wireless Dual Band Router
I have a linksy cisco and westell model 6100 and the wifi is not working-- i can only access the internet when i hook up my computer to my westell model--- whats wrong with my wifi?
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 13, 2010 | Linksys Wireless-G WRT54G Router
I have DSL/verizon,modem 6100F i keep loosing my internet connection
modem did not correct for set up and help to set correct also sorensen router need to set up for modem thank
May 27, 2009 | Westell Wirespeed LiteLine 6100...
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Beacon increase of router
hi there ;
The beacon level that u want can be changed from the settings page of the router ....
just visit the advanced wireless settings on the router . there u will be able to change the setings for the beacon interval ....
Oct 31, 2008 | NetGear WGR614 Wireless Router
Westel 327 modem setup
frcs68@hotmail.com
Oct 20, 2008 | Westell Wirespeed LiteLine 6100...
Westell Versalink, model 327W
if you are using the USB port of the modem, you should be able to see your modem while you are online, but if you are connect through ETHeRNET, you wont be able to see the modem on your device manager.
here is a USB port
and here is an ethernet port
Aug 12, 2008 | Westell Wirespeed VersaLink...
My westell 327w modem cannot detect phone or dsl line, net-work cable line, and wireless line.
Either your modem is not set-up right or you need a new modem. Call your service provider for help. They an help you trouble shoot your problem. Best help is from the Techs in India.
Jul 13, 2008 | Westell Wirespeed VersaLink...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Mtu
The modem (westell wirespeed)you have does not have is a old modem... that does have options to set the mtu settings. You need to change the modem. By the way why you need to set the MTU settings,.
Apr 07, 2007 | Westell Wirespeed LiteLine 6110 Modem
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
