Question about Dryers
Model FASE7074LWO HAS ERROR E-4
My tablet is throwing an error code 4. How do I fix it?
What is the manufacturer and model of your tablet and what is the error code? Usually a quick fix for many is a reboot, power it fully off, then power it back up again. Maybe weak batteries? It's really hard to tell without knowing the manufacturer, model number and error code.
Oct 30, 2017 | Tablets & eReaders
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Ricoh MPC4500 sc290 error code
Hello, here is the error code manual for your copy machine. Error code 290 is on page 4.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC4500&page=4
Good luck
Feb 02, 2014 | Ricoh 400879 Color Photo Conductor Unit...
4 red flashing lights on power button
That is an error code and what it is depends on the brand and model number---most sets list the error codes in the owner manual but some do not.
GOOGLE is a good source of information---Google the model number and "error codes" or "4 blinks"
Mar 31, 2012 | Televison & Video
Some times Error-2 & some times error-4.Our model is JUKI8500-7.Control box model is SV500 series. Pls advice the soluations. Regards, Kailash kailash.mehala@yahoo.com
hi there
1- your control box model is SC-500 not SV500, juki didn't made sv never ever
2- there is no error 2 just error 3 and error 4 both means there's problem with synchronizer which installed behaind handwheel first try to clean it by dray spray maby there's some oil or dust arround it. if error still coming change the senchronyzer with new one
best regards
ashraf abozid
aabozid@hotmail.com
Sep 03, 2010 | Juki DDL-8700
Clairon model number pu-2294b message on radio reads error 4 how do i clear this to reset thanks
clairon model number pu-2294b message on radio reads error 4 how do i clear this to reset thanks
Apr 23, 2010 | Clarion Car Audio & Video
What is error code F2-54 on Sharp Copier AR-C330?
1.Improper cartridge (destination error,life cycle error)
2.Identification error
3.model error
4.type error
5.destination error
6.data abnormality
7misc error
Mar 15, 2010 | Sharp Office Equipment & Supplies
What is error code F2-54 on Sharp copier AR-C330?
3.model error
4.type error
5.destination error
6.data abnormality
7misc error
Mar 15, 2010 | Sharp AR-C330 Color Copier
Sharp ar M451N F2 02
1.Improper cartridge(destination error,life cycle error)
3.model error
4.type error
5.destination error
6.data abnormality
7misc error
Jul 14, 2009 | Sharp FO 4970 Fax
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Dryers Logo
16 people viewed this question
Top Dryers Experts
