Question about Dell Inspiron 6400 Notebook
Screen Failure I just dropped a fairly light folder onto my 6400, bending the screen all the way back and causing the screen to turn off. After checking for initial visible damage(none) I restarted it, but to no avail. A few of the lights flash on and off but the screen remains off. It's also not making any noise, but they could be due to me used to noisy sever rigs. The battery is fine as it was working before the folder fell on it and I have tried swapping it out. I have a feeling the folder caused the 'hibernate' switch to get damaged so the laptop is stuck in hibernation mode. I can't see a switch anywhere for this though, I'm not even sure it has it since I've never used it before.
  • Alex_B Oct 27, 2007
    Tried a monitor and the computer started up fine, and I had full control within my OS too. I'm going to see what happens now with the local computer stores, as I doubt i have the correct tools for fixing myself. At least now I can stop them from trying to resell me an entire new laptop since I know it works except for the screen.
  • Alex_B Dec 10, 2007
    Couldn't get it working myself, well I might have been able to but didn't want to end up breaking it more than it currently is. Took it to the store and got it replaced everything is working now, and didn't cost that much in the end. They did quote me a repair price but since they wanted to do testing and all that it was going to cost more... Thanks for the help.
  • 181 Answers
Ok, first, don't just run off the battery. Plug it in to the ac adapter. Then hook up an external monitor and see if there's anything there. Try booting cold and pressing F2 to access bios. If there's an image on the external, you probly blew the inverter (easy fix, 35.00 part)
Let me know how that works out.
Good luck
Posted on Oct 27, 2007
  • jim walenciak
    jim walenciak Oct 27, 2007
    boy, I'm sure glad I could help out there. Thanks for that "almost" rating . I live for being "almost" good enough.
    Good luck with the inverter. You're gonna need it.
Need screen replaced for LG optimus C390
try a small phone repair shop, and see what they will charge
Cannot locate an LG C390, that is a Motorola phone model, so please verify model number and manufacturer
Oct 13, 2017 | LG Optimus C
Black screen, so cant turn the back light on
Couple of years ago I had the same problem. Panasonic service replaced me the LCD panel of it. After several months it has been dropped again, same failure again. I could not believe that the LCD went wrong again, so disassembled and noticed that the ribbon cable of the LCD had a contact failure. Could fix it myself. There were a couple of DIY videos on youtube...
Apr 05, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
By turning on, the 2 lock simbols lights, then everything stops. HDD is not working, screen remains black.
Most likely a Motherboard failure, remove all RAM, Drives, and connected peripherals, if no change, replace the Motherboard
Sep 27, 2010 | Dell Inspiron 6400 Notebook
VERY Dim screen after a drop
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
My sons PSP isnt working right. He says he didnt drop it but who knows. It will turn on,make sounds, and I can hear it scrolling when I scroll but the screen is blank.The screen does light up a little but...
There may have been shock inflicted on the PSP causing it to break the LCD which is fairly easy to do as they are fragile. If you are courageous you can buy a new LCD screen for it of the internet then open the PSP and swap the LCD screens.
Oct 08, 2009 | Video Game Consoles & Games
My sansa e250 mp3 player just fell down, after that, when i restarted it it is just showing the blue light but not showing the display on the screen. Any help would be appreciated.
Drop it again from a similar height
OK this is going to be hard to believe....the exact thing happened to mine. It dropped about half a meter onto a concrete floor and showed up with a blue screen and wouldnt shut off.
I unscrewed the back panel and unplugged the battery hoping that it would reset. After several restarts and unplugged batteries it was still unresponsive with the blue screen of death. So like any good tech i tried to reproduce the sequence causing the failure. I dropped it onto my work bench and plugged the battery back in. Worked perfectly after that and has continued to work perfectly since (nearly a year later).
I made sure i covered it with one of those cheap silicone covers after to hopefully absorb some shock after i got it working again. After a year of brutal treatment on military exercises this is the one and only problem i've ever had with my sansa.
Good Luck
Dec 30, 2008 | SanDisk Sansa e250 MP3 Player
Lost desktop files and folders
Check in 'trash' if they are there, then simply drag back onto the desktop.
Oct 15, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My toshiba screen
Shine a torch light onto the screen. If you can see a faint outline of the images, it could indicate a back light failure. Unfortunately, you cannot fix this by yourself. You will need to take it for servicing.
Jun 11, 2008 | Toshiba Satelite A10 Notebook
Camera not working
Could be back light has failed[ can you see any feint images at all? Or a connector has come adrift or a board failure of some kind. If the camera if fairly new then get onto Gateway tech support. If it has no warranty left -I fear the price of a repair will be more than the camera is worth but you can try for a repair.
Jun 06, 2007 | Gateway DC-T50 Digital Camera
Dell Inspiron 6400 Notebook Logo
67 people viewed this question
Alun Cox
