Question about Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w
Pada lcd printer dcp-j140 muncul tulisan black ink cannot deteck reinstall slowly dan kode tanda seru berkedip terus
  • 3 Answers
SOURCE: Sir
Unfortunately the DCP series are part of Brothers new POS technology range.
These often suffer two common problems.
1. Alignment issues.
The work a round is to turn off BiDirectional Printing.
2. The ink sensors fail.
The work around is to put tape over the bump in the ink cartridge.
This makes the printer think the cartridge is always full.
Be careful though not to let them run dry or you might clog the system or head.
Note: both issues can be repaired by a service center. But is this cheap unit really worth the cost? :(
SiliconJaguar
Posted on Jun 11, 2008
the kowalski
  • 86 Answers
SOURCE: brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Posted on Jun 03, 2009
  • 355 Answers
SOURCE: printer is showing
unplug cartriage and then try again
Posted on Oct 05, 2009
SOURCE: My dcp-585cw printer is not printing black. I
I have this same problem :(
Posted on Jan 28, 2010
raman_jhanje
  • 27 Answers
SOURCE: My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
Posted on Mar 05, 2010
Tanda replace cleaning web artinya apa ??
artinya anda harus mengganti cleaning web,
bentuk sparepartnya seperti kain canvas warna putih di gulung,
fungsinya membersihkan pres rool dan hot roll.
tapi biasanya kalau cleaning web habis atau tidak jalan muncul tulisan di layar E0005.
Feb 24, 2013 | Canon NP 6035 Copier
Printer canon mx 366 saya. error 5B00. tidak bisa berpungsi ketika di hidupkan muncul error 5B00. sudah dilakukan reset manual tapi tak ada hasi. masuk ke menu tidak bisa. mhn petujuk untuk masalah ini....
I have best solution for reset error 5b00 Canon MX366 about waste ink absorber full :
1. Fisrt step : entering service mode, using this method (dont use other method!) press & hold "stop" button and than press "power" button, release "stop" button and still hold "power" button and than press "stop" button about 5 times ( 1, 2, 3 , 4, 5) and release "power" & "Stop" button.
2. Printer will be entering to Service Mode with indicators " Printer LCD to become full drak and CPU detecting new hardware (dont do anything).
3. Download Servicetool V 1074 for Canon IP2770, download and entering to this Sofware.
4. prepare paper on the printer and Clik "MAIN" on the Menu Servicetool V1074, if success canon MX366 printing "D=000.0
5. turn off Canon MX366 and remove power cord, wait about 60 second, reinsert power cord and turn on your printer,....... o la la la your printer was normal,..... ( ngono ae kok mumet)
6. if you have any qustion, send your email to : alfa_centrino@yahoo.co.id, thanks God bless U
May 15, 2012 | Office Equipment & Supplies
Nokia 3120 Classi Supportive File Noting to Display
Pada program jika dipilih muncul tulisan "Supportive file. Nothing to display."
Untuk nokia 3120 classic, bisa dicoba alternative ini:
-> Pastikan progam yang hendak dipakai sudah diklik "options" atau bisa diatur dulu "application access"! (Supaya program dapat muncul)
-> a. Pilih "menu-settings-display-active standby-active standby mode (on)
lalu pada posisi standby pada shortcut bar pilih "options-select shortcuts-application list-silahkan pilih programya (ditandai)
pilihannya:
done-done-(save change? Dan pilih "yes"
Lalu pada posisi standbay pada shortcut bar, dipilih program2 yang sudah dipilih
b. Cara yang ke 2 bisa memanfaatkan tombol shortcuts:
"Menu-settings-display-my shortcuts-left selection key atau right selection key atau navigation key-application list-pilih programnya
Pada posisi standby, silahkan dipilih pilihan tombol shorcut yang sudah diatur
*Semoga bermanfaat
Jan 28, 2012 | Nokia 3120 Classic Cell Phone
Hidup tapi tidak tampil
SAYA PUNYA LEPTOP MEREK AXIOO SAYA HIDUPKAN ADA TAMPILAN TULISAN AXIOO NYA SETELAH ITU UNTUK TAMPIL KE WINDOWS (WELCOME) SELAMTAN DATANG TIDAK MUNCUL YANG KELIHATAN TANDA PANAH MOSE SAJA DAN TIDAK LODING KE WINDOWS.
Nov 30, 2011 | Computers & Internet
Saya punya printer Epson Stylus TX111.. pada saat dinyalakan dan dimatikan catrigde tidak bergerak dan lampu merah dua-duanya menyala.. sebelum kejadian ini muncul tulisan servis..(sy agak lupa tulisan...
Something's probably jammed in there. Get it out in the light with some paper to feed through, clean out the gunk in the paper path or cartridge area, perhaps running through a cleaning cartridge, and try for an error message.
Sesuatu mungkin macet di sana. Dapatkan keluar dalam terang dengan beberapa kertas untuk memberi makan melalui, membersihkan gunk di jalur kertas atau area kartrid, mungkin berjalan melalui cartridge pembersih, dan mencoba untuk pesan kesalahan.
Jul 25, 2011 | Office Equipment & Supplies
Power on lensa tidak mau keluar.muncul tulisan turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN ditampilkan pada layar LCD saat Mekanisme Lensa macet atau ketika terpengaruh oleh kerusakan apapun. Jika memutar power on dan off lagi tidak menyelesaikan pesan kesalahan, coba lakukan reset kekuasaan dan Inisialisasi pilihan.
Melakukan reset tenaga manual
Matikan kamera.
Keluarkan baterai.
Tekan terus tombol daya selama 30 detik.
Biarkan kamera untuk tetap tanpa listrik selama 60 detik.
Masukkan kembali baterai.
Hidupkan kamera.
Untuk mengatur ulang Kamera kembali ke default pabrik, pilih Opsi Initialize dari Menu Utama Pengaturan 1 dari Kamera ke OK.This akan mengatur pengguna menentukan pengaturan kembali ke default pabrik. Gambar-gambar dan video tidak akan bisa dihapus.
Jika masalah berlanjut, mungkin diperlukan layanan.
Terima kasih telah menghubungi FixYa.
Feb 23, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w Logo
500 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
