Question about Ranger Communications RCI-6900F-25 CB Radio
How to change a memory battery in an RCI 2970
  • 38 Answers
Its the round dime sized battery on the back of the cpu inside (back of faceplate) there is an battery upgrade. www.cbtricks.com
Posted on Jan 10, 2016
2 Suggested Answers
anymhz
  • 500 Answers
SOURCE: RCI 2970
broken coax inside the radio going to the amp.. is the display ok? sometimes static from storms will knock out the processor and the radios will quit. have to replace the cb shop temple, tx on yahoo search processor board. to restore operation on that problem. is there more info can help us with?
Posted on Dec 08, 2009
Rci 2970 blown fuse
open the fuse holder in the back of the radio get the number off it. It will probably be a 5 amp fuse but whatever ,replace it with the same one.
Apr 05, 2013 | Ranger Radio Communications
Audio in my rci 2970 has no punch to the audio
cut back on the power,turn up the modulation and you should be good.
Dec 25, 2012 | Ranger Radio Communications
I have a RCI 2950 comes on keyed up and stays keyed untill you turn it off. I have replaced the auto amp, all voltage regulators and the black diode with yellow strip below mic plug with no change. I need...
i have the same radio rci 2950. Ive had the same problem with mine,turns out with mine the processor would lock up,turning the radio off & on repeadly would clear the problem and the radio would work fine x-mit & recieve. the solution to fixing the problem is to replace the memory backup battery this battery works similar to a computer motherboard cmos battery when this battery goes dead all sorts of strange things happen to the radio wont transmit wont recieve or like your problem transmits continiously. the problem with replacing this battery is finding out what year & model your ranger 2950 is. the internet says only first generation ranger 2950s use the battery second genration & third generation do not use the battery. but the internet could be wrong. so i suggest getting a hold of (usa ranger.com) & give them a phone call or email and ask them about the year your radio was made. they may even service it for you or if you are electronic savvy you can do it yourself. the battery is located close to the main cpu on the front panel if yours uses a battery.
Sep 07, 2011 | Ranger Communications RCI-6900F-25 CB...
Need operating instructions for RCI-6300F150
You can download and print the operating manual for your 10-meter transceiver here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_om.pdf
In case you need it, you can also download and print the service manual here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_sm.pdf
Bill B.
Oct 25, 2010 | Ranger RCI-6300F-150 Base Scanner
RCI 2970
May 06, 2009 | Ranger RCI-6900F-150 CB Radio
Galaxy 88hl
this type of modification is not recomended and will ultimitaly cost you a good radio.the amo in a 2970 requires a lot of modification to the galaxy 88 I have not seen or heard of anyone who has done this modification successifly usually they eng up with 2 radios that nolonger work.
Mar 05, 2009 | Radio Shack TRC-447 CB Radio
RCI 2970 squeels until you unplug the external speaker and plug i
Strange! I used to run almost the same kinda setup but with a super scanner omnibeam, i modded mine myself. At 1 time i had a squeal problem it was in the mic if i remember correctlly i ran a external wire from the screw on the spring inside the mic where the cord comes out to the radio chassis and it stopped it give it a try. I used a simple speaker wire, also you might want to try grounding the radio to the power supply. Sounds like a ground problem! I have a awsome mod for that radio that would enable you to run a regular amp with it and also would enable you to talk local without engaging the amp in the radio using only 4 watts! Let me know how it works out for you with the squeal? if intrested in that mod contact via email at (noteethontop@yahoo.com). put 2970 in the subject line. Take care.
Jan 17, 2009 | Radio Communications
No channel readout in front of radio ranger 2950
replace memory battery its a CR2032 battery Radio Shack and Walmart has them from $3.65 to $5 in price.
Jan 11, 2009 | Ranger Communications RCI-6900F-25 CB...
Ecoquest FreshAir - UV Flickering
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
Eric
Download PDF Manual
Feb 17, 2008 | Ecoquest Fresh Air Air Purifier
Ranger Communications RCI-6900F-25 CB Radio Logo
135 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
