Question about Tech Solution TS-4500 Shredder
A mobile station traveling at a speed of 60 km/h transmits at 900 MHz. If it receives or transmits data at a rate of 64 kbps, is the channel fading slow or fast?
Processor upgrade
WHERE IS THE QUESTION.
Feb 24, 2015 | Max Computers & Internet
What does WCDMA 2100/1900/900 on a nokia e5 mean?
short answer
this tells you that the phone is what is know as as tri band phone and will work on any of the 3 stated UMTS networks frequencies.
check country of travel to ensure compatabilty.
long tech answer.
the term Wideband Code Division Multiple Access means that you phone is code divisional and will only react to a call that is made that is for your phone, even if more calls are being received on the same frequency the other are ignoted and you have full security of your call. you phone can decipher which is the call for it and accept the call this is used to save on network frequencies. under the
wireless Universal Mobile Telecommunications System networks.
2100 is the mhz range 1920-2170 mhz as used in Europe, Asia, Africa, Israel, Oceania, Brazil, India
1900 is the mhz range 1850-1990 mhz as used in Americas, Chile, Venezuela, Colombia
the 900 is the mhz range
880-960 mhz as used in Asia the carabien and europe.
so as long as you have a roaming agreeming with your local provider this phone will work in most places in the world.
Feb 25, 2013 | Gund Gobbles Thanksgiving Hoedown Musical...
Icom IC-7200 transmit problem on 1600.000 kHz to 1999.999 kHz
If the radio is made to be sold only in the US then the phase lock loop is disabled when your are trying to transmit out of the US band edges. Try looking up a MARS circuit mod for this model and it amounts to only clipping one end of a diode to enable the transmitter on all frequencies.
Nov 12, 2017 | Icom Radio Communications
A bicycle travels 12 km in 40 min. What is its average speed in km/hr?
18 km/hour
The bike is traveling at the speed of 12/40 = 6/20 =18/60
18 km/60 minutes
Jun 21, 2011 | Computers & Internet
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
What are the features of hp cellular?
General 2G Network GSM 850 / 900 / 1800 / 1900
Announced 2006, February
Status Discontinued
Size Dimensions 118 x 71 x 18 mm
Weight 179 g
Display Type TFT resistive touchscreen, 65K colors
Size 240 x 240 pixels, 3 inch
- QWERTY keyboard
Sound Alert types Vibration; Polyphonic ringtones
Speakerphone Yes
Memory Phonebook Practically unlimited entries and fields, Photocall
Call records Practically unlimited
Internal 64 MB RAM, 45 MB ROM
Card slot miniSD, buy memory
Data GPRS Class 10 (4+1/3+2 slots), 32 - 48 kbps
EDGE Class 10, 236.8 kbps
3G No
WLAN Wi-Fi 802.11b
Bluetooth Yes, v1.2
Infrared port Yes
USB Yes
Camera No
Features OS Microsoft Windows Mobile 2005 PocketPC
CPU Intel PXA 270 416 MHz processor
Messaging SMS, MMS, Email, Instant Messaging
Browser HTML (PocketIE)
Radio No
Games
Colors Silver
GPS Yes
Java No
- Pocket Office (Word, Excel, PowerPoint, PDF viewer)
- MP3/AAC/AAC+/WMA/OGG/AMR player
- WMV/MP4 player
- Organizer
- Voice memo
Battery Standard battery, Li-Ion 1200 mAh
Jan 07, 2011 | HP HW6910 Cell Phone
Toshiba Portege 7200 i try to fomat it it does no format why
Windows won't as a rule allow format of an older system onto a newer system, it goes into protect mode.
If you are trying to format the laptop with say XP and you have XP with SP3 installed, because SP3 is newer than XP it will try to stop you from destroying the newer system. Matbe you are running out of space?
Processor
Mobile Intel® Pentium® III processor at 600 MHz featuring Intel® SpeedStep™ technology, 256 KB 2nd level cache, 100 MHz Front Side Bus
Memory
Standard 64 MB SDRAM, expandable to 320 MB
Hard disk
12.0 GB1) capacity, S.M.A.R.T. hard disk
Internal video modes
1,024 x 768 x 16.7 million colours Display
13.3" (33.8 cm) TFT active matrix colour display
Battery
Removable lithium-ion battery, 2-3 hrs battery life, with extra high capacity battery up to 5 hrs
Size and Weight
297 x 241 x 25 mm, 2 kg
Diskette drive
External: 3.5" 1.44 MB/720 KB
DVD-ROM drive2)
6-speed (max) with optional DVD Network Dock II, 12 cm (5.25") and 8 cm (3.5") disks, data transfer 3,600 KB/sec, average access time: 140 ms
Graphics adaptor
128-bit graphics accelerator, SVGA-/VGA compatible, AGP bus, 64-bit BiTBlT, 4 MB internal Video RAM
External video modes
640 x 480 x 16.7 million colours,
800 x 600 x 16.7 million colours,
1,024 x 768 x 16.7 million colours,
1,280 x 1,024 x 65,536 colours,
1,600 x 1,200 x 65,536 colours
Up to 85 Hz refresh rate
Keyboard
86 keys, 12 function keys, 8 dedicated cursor keys, inlaid numeric keypad, 8 Hot Keys, 2 Windows® keys, AccuPoint™ II, Euro key
Sound System
16-bit stereo Sound Blaster Pro compatible, 3D-wide mode, MIDI & Wavetable synthesis, volume dial, built-in speaker and microphone
BIOS
ACPI (1.0b) enabled BIOS, SM BIOS V. 2.3
Expansion
2 x PC Card Type II or
1 x PC Card Type III, CardBus support, memory expansion slots
Communication
Integrated international V.90 modem (56 Kbps data, 14.4 Kbps fax)
Interfaces
FDD connector, external monitor, USB, Fast Infrared Port, I/O adaptor connector, RJ 11 modem jack, headphone, external microphone, slot for Kensington Cable Lock
With I/O Adaptor:
serial, parallel, PS/2™ mouse and keyboard
With Docking Station (DVD Network Dock II):
serial, parallel, external monitor, PS/2™ mouse and keyboard, video out (NTSC/PAL), line-in, line-out, integrated FDD, includes built-in Ethernet (Wake-On-LAN and Service Boot support), 6-speed DVD-ROM drive
Power supply
Autosensing 100-240 V AC adaptor for world-wide usage
Casework
Magnesium alloy
Bundled software
Windows® 95 and Windows® 98 selectable installation, Windows® NT 4.0 on request (limited language versions available), PC Card management software, Toshiba utilities and drivers (all pre-installed on the hard disk)
Bundled hardware
External diskette drive, autosensing AC adaptor, I/O adaptor
Special features
Toshiba Hibernation and Resume, Toshiba Power Extensions, System Password Securities, HDD password on request, SecureSleep™, LANDesk Client Manager (LDCM), Wake-On-LAN and Service Boot support (with manageability software and LAN chip), Recovery CD, 3-year international warranty
Options
DVD Network Dock II, carrying case, extra high capacity battery, battery charger, 32, 64, 128 and 256 MB memory modules
Dec 31, 2010 | Toshiba Portege 7200CT Notebook
DO THE DCT700 CABLE BOXES HAVE AN TV TUNER BUILD INSIDE THEM?
RTFM!
  • MPEG-2 digital video processor
  • ATSC standard Dolby® Digital (AC-3) Audio Processor
  • ITU standard 64/256 QAM/FEC enhanced adaptive equalizer
  • On-board real-time RF return (256 Kbps)
  • Bitmapped graphics display (4-/8-bit)
  • 90-860 MHz Tuner
  • DES-based encryption DCII access control
  • Digital diagnostics
  • Frequency agile 2.048 Mbps out-of-band data receiver
  • Macrovision copy protection
  • IR support for remote control
  • RF remodulator output (ch. 3, 4)
  • Baseband video and audio outputs
Jul 20, 2010 | Arris DCT700 DTV Receiver
Which is best for gprs nokia 6303 or nokia 5800?
Nokia 5800 Offers Very High Speed As Compared to Nokia 6303.
Nokia 6303 Classic mobile phone along with standard GPRS Multislot Class 32 connection with upto 107 kbps speed also offers faster data transfer options using EDGE Multislot Class 32, 236.8 kbps speed connection.Nokia 6303 Classic mobile phone along with standard GPRS Multislot Class 32 connection with upto 107 kbps speed.
On the Other Side, Nokia 5800 could Offer Speed upto 296/177 kbps.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Nokia Cell Phones
Tech Solution TS-4500 Shredder Logo
67 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
