Question about Samsung Digimax D53 Digital Camera
Camera wont turn on
I have a samgung D53 and when i push the power button the camera makes some noises and shuts off. the lens will not open or telescope out.
  • 2 more comments
  • bp34 Nov 09, 2007
    my camera makes a three beeping noises then shuts off. no operations work.
  • KD79 Dec 25, 2007
    I am having the exact same problem. I got it last Christmas and it has worked wonderfully till a couple of weeks ago. I tried both types of batteries and have not been successful.
  • Anonymous Dec 25, 2007
    i changed the battiries and it still dont work
  • jacq77 Mar 15, 2008
    We have the same problem with our camera as well. (2 actually) We swapped batteries and 1 of the cameras turned on and is working now, but the other one still just beeps and shuts off after a couple of seconds. We use the rechargeable non-alkaline. Any suggestions?
I got my camera 2 christmases ago, used it that day, and then not since, because I needed to buy a memory card. Then I put it back in the original box which got stored in another box, and I forgot that I had it. I was reminded of it and decided to go and buy a memory card to begin using it. I put in new batteries (out of the package today) and it turned on, beeped 3 times and turned off. I tried this solution with every kind of battery I could find, and still nothing. What am I supposed to do with it now?
Posted on Mar 13, 2008
    Scholar:
  • 97 Answers
As i've posted with many other problems like this, ensure you aren't using alkaline batteries. I have had similar problems with Samsung cameras before. The one I was using behaved much better on rechargeables or oxyride disposable batteries. It's nuts that this one was supplied with a pair of alkalines in the box :(
Posted on Nov 09, 2007
Camera has charged batteries. at first when i turned on power...nothing happened...then...later...i pressed power again and it came to life. the lens popped out and i took a bunch of pics and reviewed...
@ alan o'brien, Samsung D53 digimax draws a lot of current from the battery thus, you need to replace your batteries with a HIGHER current ratings, sufficient enough to run the motor. This miniature motor inside the D53 camera drives the reduction gears functions, to extend and retract the mechanical lens. During this processes it is drawing a lot of current from the battery. In order to conserve and prolong battery power avoid zooming in and out, utilize the function speed 50-400 and manually adjust aperture to minimize the unnecessary use of flash. In other words, go manual mode. Here's the battery specs. 2800ma NiMH rechargeable battery. Refer and follow manufacturers recharging instructions for best result. Do not leave batteries inside the camera even when not in use because the circuit inside is still on the standby mode and not necessarily off. Hope i have satisfy your curiosity. If you can, kindly share with me some of your best photo taken from your D53 digimax. Thank you.
Sep 22, 2013 | Samsung Digimax D53 Digital Camera
Samsung digimax d53 beeps then shuts off with lens stuck out
The camera lens is jammed, caused by dirt or worn out gears. a camera technician would be solution but not cheap, or you can take matters in your own hands and try a risky trick "NOT RECOMMENDED" take the palm of your hand and sharply hit it around the lens housing and applying power as you do so in an effort to get lens to retract, if you are lucky it will work or make things worse.
Mar 10, 2012 | Samsung Digimax D53 Digital Camera
The lens is stuck open and nothing will work. Every time I try to turn it on or push a button it beeps and turns off.
First, make sure you have a charged battery. Once you have that, try turning it on, and gently press on the lens to try to help it reseat. You might try googling the problem, there are free suggestions to try before you take it to a repair facility. But if you do decide to have a shop fix it, get an estimate first. Oftentimes, the repair is about what you will pay for a good, used camera on Ebay.
Feb 22, 2010 | Samsung Digimax D53 Digital Camera
My kodak easyshare V1253 Powers up, then shuts off
You have damaged your lens. If the camera can not move the lens it goes through a built in diagnostics test and shuts down. Beyond repair as cost to replace is beyond the value of your camera.
Jul 03, 2009 | Cameras
When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Nov 11, 2008 | Olympus FE-220 Digital Camera
3 beeps
had the same problem with my D53 eneded up buyin a new camera pulled the D53 out the other day was going to toss it then i noticed the lense was just a lil crooked i played with it a freed it up camera works great now
Sep 23, 2008 | Samsung Digimax D53 Digital Camera
Lens stays neither closed nor opened when power off
try to slightly push it in slowly while it is going in manully
Apr 03, 2008 | Samsung Digimax D53 Digital Camera
Camera won't work
I had the exact same problem. Camera turned on but turned off soon after, with lens still outside. Not to mention that awful beeping noise. I noticed the lens was crooked as if it was stuck. I pulled it out and I heard it click into place, for a second I thought I had broken it. I then turned it on . waited & it remained on, I turned it off and the lens went in and it turned off! It was working again. Good Luck!
Mar 19, 2008 | Samsung Digimax D53 Digital Camera
Help
Try Energizer rechargable nimh batteries with 2500 mah. I had the same problem and using these batteries solved the problem.
Dec 05, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Digital Camera Logo
47 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
