Question about Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine
Generator stopped running. 3500 hyundia. wont start any more. taught it over heat. let cool off. still nothing
Greetings: I have a 3500 wts 6.5 Nikota generator, turn on and off several seconds. The carburetor is fine, ignition, too. The shoot off well, I would like to give me an idea that can be
you saying it wont keep running
you have spark at the new spark plug
fuel is fresh and uncontaminated
could be
the coil or the plug lead
ok when cool ... fails when hot
the Governor setting
carby jet blockage
if a four stroke a valve adjustment might help
Oct 12, 2016 | Electrical Supplies
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    My Oman generator overheats and shuts down if I plug my battery charger in and have my air conditioning on and or coffee maker
    to start with with an air conditioner running (2000 +watts ) plus a coffee machine (1500 watts ) you are looking at 3500 + watts of power used from the generator
    the genset has to be of a minimum of 4500 watts to run full time with out over heating
    never mind what the rating says on the side, that rating is surge rated and the duty cycle is around 500 watts less than that figure
    So if your gen set is 3500 watts the power is at surge power and that will overheat the genset
    Of course you haven't mentioned the rating of the set , but overloading is the main reason for over heating
    Jun 06, 2016 | Electrical Supplies
    Dr comes up wont start
    dr is door error
    this generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires)
    you can inspect these relay connection visably by removing the front control panel
    you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay
    this is not a factory taught test.
    its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is gone.
    Jan 04, 2015 | Washing Machines
    1998 Hyundia Tiburon would stop after engine got hot and after cool down would start and run fine. Now after it has been sitting for awhile(7 months) it will not start! (it crankes over good) no gas or no...
    It's a sensor. I had one that was cracked. When the car warmed up the heat caused the crack to expand and the sensor wouldn't work. After the car cooled it was fine until it got hot again. The sensor is probably gone for good now. You would need diagnostics or troubleshooting to determine which one. You can get a hand held diagnostic computer for cars. Some auto parts stores check for free. You could see if any does a loan-a-tool.
    May 27, 2011 | 1998 Hyundai Tiburon
    Tried to start the truck---nothing happened....the ignition key was turned on but nothing. 3 days ago, same thing happened I turned key and nothing. So what I did---turned key on till red light came...
    sounds like a bad connection,it wont heat up the solenoid or the starter,check your hot and negative cables from battery to starter first could be the starter itself, ggod luck
    Dec 20, 2010 | 1997 Chevrolet C/K 3500
    Hot chain saw wont start
    When it won't start, remove the spark plug, lay the base on engine metal with the wire on, and pull through. The spark should be blue and snappy. If nothing, try a fresh plug. If still nothing, the ignition module may be failing with heat. Try blowing out sawdust from the engine and case with compressed air to improve cooling. Does the engine 4-stroke when not cutting, but immediately 2-strokes when cutting? Check the air cleaner and muffler for plugging. Make sure the carburetor fasteners are tight. Hope some of this helps!
    May 01, 2010 | Garden
    Generator will start and run easy, then just die.
    Check for loose wiring connections, especially at the run or kill switch. Generators vibrate a lot so it could be as simple as something loose.
    Jun 15, 2009 | Electrical Supplies
    My car stops on motion
    several things it could be
    alternator replacement
    relay is bad
    computer going bad
    over heat saftey feature thats killing the power so you dont crack your block
    make sure your fan is running and hook power to fan direct to an power fuse this is when you turn the key to on the fan starts running you can also add a toggle switch to cooling fan so when in accessory it wont run down battery
    your vehicle is equipeted with an electric cooling fan if this shuts off your vehicle over heats and shuts off
    this ensures vehicle is always running cool
    May 11, 2008 | XO Vision GX1211 XOVision 12" Roof Mount...
    Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine Logo
    19 people viewed this question
    Top Porter Cable Electrical Supplies Experts
    John Trevino
    Spud Howell
    Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
