Question about Zebra LP 2844 Thermal Printer
LP UPS 2844 streaks in the printing
When I print a label, there is a strip that prints out that's lighter than the other parts
SOURCE: Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Posted on Jan 21, 2008
jigeo
  • 57 Answers
SOURCE: Zebra LP 2844
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Posted on Apr 24, 2008
  • 10 Answers
SOURCE: my lp 2844 will not print
Firstly is your label Thermal Direct?(DT)
To test quickly score your fingernail across the surface of the label, if it leaves a black mark then it is DT
If there is no mark then it is probablly Thermal Transfer(TT) and requires a ribbon, which you cannot use on the LP 2844, only on the TLP2844.
If you have DT labels then go into the printer driver via Printers & Faxes and the Printing preferences and change the darkness to level 7.
Try printing again.
If it works then cahnge the darkness again until you get a satisfactory print darkensss.
If it still does not print then change the darkness to maximum, does it print?
If not then I think you have a duff printer, return it to the company that supplied it for repair.
Any problems contact Lancer labels
Posted on May 15, 2009
  • 14 Answers
SOURCE: 2844 UPS Printer Prints Duplicate Labels
The quick and simple answer is to use a different driver instead of the 2488 driver that UPS provides, that is where the problem lies..
Under printer properties, Advanced Tab, I changed the printer driver to Zebra S4MDT-200dpi and now the printer works fine. Prints labels correctly, and most of all only one label at a time... The drivers are there in the UPS software, just change which one you use and go...
John Plemons
Posted on Aug 12, 2009
  • 97 Answers
SOURCE: Zebra LP 2844 doesn't feed label all the way out
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
Posted on May 06, 2010
Label splits
because if label lengh is ex. 20mm and you set up label print area as 21mm, it will over the size and it will skip the next one. the print area shoul be less than the label length. please verify software or driver.
Jan 22, 2014 | Zebra LP 2844 Thermal Printer
Doesnt print all the way to bottom of label
I had the same issue with my Zebra printer. Make sure your margins are set correctly, and you have the correct size label selected. This fixed my problem.
Aug 07, 2012 | Zebra LP 2844 Thermal Printer
Zebra only prints after restart
UPS VOLTEGE PROBLEM PLEASE INSTALL HIGH VOLTGE UPS
Apr 13, 2012 | Zebra LP 2844 Thermal Printer
Zebra thermal printer 2844 printing double on ups.com. printer preferences set to 1 copy.
hi,
- Turn off the printer.
- open it and check the labels roll.make sure its correctly fixed.
- close the printer.
- press and hold the green button and switch on power.
- release after it starts red light flashing.
- the printer will run a self test.
- turn it off and then on again.
- re-check the settings of the printing software.
- now print.
thank you!
Sep 08, 2011 | Zebra LP 2844 Thermal Printer
My ups thermal printer zebra lp 2844 wont print labels properly
press button until flash 7 times to calibrate, turn off, tur on again if pressist, check the setings from the driver, if thei correct. ajust if necessery.
Jul 05, 2010 | Zebra LP 2844 Thermal Printer
Zebra printer is printing two copies when only 1 is checked
Same problem exactly and was not able to get a response from UPS or the zebra company, someone please help!!!!!!!!!
Mar 19, 2010 | Zebra LP 2844 Thermal Printer
My lp 2844 will not print
Try printing again.
Apr 05, 2009 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
29 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
