Question about GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW Side by Side Refrigerator
Msd2560hes freezer ok ref not cooling - GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW Side by Side Refrigerator
4 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: ref no cooling freezer okay
There's alot of things to check here, David. But, since it's a GE, I'll assume a defrost problem 'cause they are known for those issues. Is there ice/frost buildup on the rear wall of the freezer? If so, it's not defrosting. 3 things will cause a "no defrost" condition. Failed evaporator thermister, Failed defrost heater and failed electronic control. Your model has problems with the first 2, rarely the 3'rd. You can get your machine cooling again by manually defrosting it. Simple, unplug it for 24 hours and leave the freezer door cracked open an inch or so. After time is up, plug it back in and it'll cool just fine for a week maybe two, 'til the frost builds back up again. This'll buy you time to get parts and do the repair and besides... it has to be done anyway. Even if you had the parts in hand and did the repair right now, you'd still have to manually defrost it. Post back and let us know.
Posted on Aug 01, 2007
woodchuck789
  • 4066 Answers
SOURCE: the coil in the freezer is freezing up and when it
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Sep 28, 2009
heatman101
  • 43501 Answers
SOURCE: my ref is not cooling, sometimes its cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 04, 2011
My ref is not cooling, sometimes its cold sometimes its not. but the freezer works ok.
heatman101
Sep 04, 2011 | GE Refrigerators
R5267lbbp ref side temp jump around freez ok
heatman101
Jul 26, 2011 | Samsung Refrigerators
Danby ref Model no. DFF 1170brwy do seem freezer is ok but ref side is not cooling. thanks
most likely you have a defrost issue click this link to see why http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm you need to remove the rear panel inside the freezer to assure that you do not have an ice build up and also that the fan located above the condensor is working properly as well if you have any further questions message me back Thanks Rick
Mar 14, 2011 | Danby DFF1144W Top Freezer Refrigerator
Freezer works fine but refrigerator side is not cooling
yes ok. try the control to your right and it should say like freezer colder and warmer. by making the freexer a little warmer it will make the ref. colder. u r just turning a baffle so more cold air from the freezer will go into the ref, to make it colder.. ok
Feb 13, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
I have a Kenmore fridge with the freezer on the bottom model # 52600. What is happening is the fridge is not cooling but the freezer works.If you have any suggestion please e-mail me. thanks
if the freezer is ok,the damper of the ref side is close need to adjust or replace,2 is the sensor is the sensor is defective the ref side not cooling even the sensor of freezer side if defective may cause why not cooling in ref side,its hard explain to remove or to check the unit by its your self,much better call an service technician to check what the exactly coz why not cooling,and you get a warranty for the service compare you buy a part,but you dont know what how to test the part if is ok or not.
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Jenn Air ref/freezer not freezing/cooling
Take the back out of the freezer and check and see if the refrigerator is in defrost while it is cooling if it is replace the timmer, then check and see if the fan on the underside is working if not replace the motor this will cause the problem also.
If all that is ok feel the small line under the refrigerator ( high side) and see if it is hot while it is running if not check the freon in the refrigerator.
Mar 03, 2008 | Refrigerators
GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW Side by Side Refrigerator Logo
23 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
