Question about Sport & Outdoor - Others
My winchester 1200 will not eject the shells
Once the shell is fired the ejector will not eject the shell i have to take apart the gun and tape the shell out. it seems like the ejector poling the shell at an angel. what do i do?
4 Suggested Answers
SOURCE: I have a Winchester 1400 that fails to eject low
Hello Ron,
Without looking at the gun it is hard to diagnose, but what runs across my mind first is at the font of the magazine tube there should be a valve cap assembly. The valve cap assembly is basically a plunger and a spring, which vents extra gasses away from the mechanism. It sounds to me that either the spring in the assembly has either become weak or more likely fouled with carbon deposits which is causing it to stick open somewhere and venting a little too much gas for the low power shells to work the mechanism.
Unfortunately, as you probably already know, there doesn’t seem to be a way of disassembling the valve cap assembly to clean it. So, every once in a while I take the valve cap off of mine and submerge it into a product called Kroil, which is a very fine penetrating oil, you can get Kroil at www.midwayusa.com or some gun shops carry it. Soaking it always gets some stuff out of it for me. You could probably also use gun scrubber, however I just choose not to. Anyway, good luck with everything.
Jay
Posted on Aug 13, 2010
  • 6982 Answers
SOURCE: My shell for my winchester
Your Winchester 70 (for which you did not list a caliber) is likely not the same as your 270 (which is a caliber, not a model number) If you look on the barrel (generally stamped right below the iron sight or just before the barrel joins the gun), you should find the caliber of the rounds for expected use.
If you did not buy the weapons new, there is a possibility that one of them was re-chambered for a "wildcat" round. In that case a factory brass may be longer than what you need, preventing you from closing the action.
Any competent gun store employee or a local gun smith can easily find the correct ammunition for your weapon.
Remember....the model such as for example a Remington 700 is a model. That weapon is chambered for many different rounds but you cannot interchange them.
Posted on Nov 24, 2010
SOURCE: model 70 270 win will not eject spent shells
The ejector pin becomes flattened with sharp edges... it shaves brass, the brass helps stick the pin which is also penned out and a bit larger now. I took mine out and honed it so that it did not shave brass and would slide easily in the hole.... Make sure your spring is back in before you try the pin (You want something to push it back out). Most important... don't let the pin and spring get away from you. You can look on a chambered and ejected cartridge to see exactly where the bras is being shaved from. In my case it was the very back, outer flange, indicating the ejector pin.
Good luck ... hint... really use your eyes
Posted on Nov 02, 2012
Anything you can tell me about Winchester Model 97 Ser# 201413. when it was made and value.
The Winchester Model 1897 evolved from the Winchester Model 1893. The Model 1897 and 1893 were both designed by John Browning. The Model 1897 is an external hammer shotgun lacking a trigger disconnector. This means that the user can hold the trigger down while cycling the shotgun and once the action is returned to battery the gun fires. The gun itself is classified as a slide action pump shotgun. It was the first truly successful pump-action shotgun produced. Throughout the time period the Model 1897 was in production, over a million of the type were produced in various grades and barrel lengths. 16-gauge guns had a standard barrel length of 28 inches, while 12-gauge guns were furnished with 30-inch length barrels. Special length barrels could be ordered in lengths as short as 20 inches, and as long as 36 inches. Along with various grades and barrel lengths, the Model 1897 came in two different chamberings. One was the 12 gauge and the other was the 16 gauge. The shells should be of the 2-¾ inch or 2-? inch model. Any shells larger are not recommended. An average Model 1897 held 5 shotgun shells in the magazine tube. After including the one shell that could be held in the chamber, the average Model 1897 held a total of 6 shotgun shells. However, this would vary from grade to grade. When working the action of the Model 1897 the forend (fore grip) is pulled back, forcing the breech bolt to the rear which extracts and then ejects the spent shell while simultaneously cocking the external hammer by pushing it to the rear. When the forend is slid forward again, the breech bolt pushes a fresh shell into the gun's chamber and locks into place. This action of sliding the forend back and forth (pumping) is why the gun is classified as a slide action (or pump) gun.
Oct 23, 2016 | Winchester Optics
This rifle has not be used much. Maybe 500 rounds. Problem is it does not eject the casing fired or unfired. It pulls it from the firing chamber but does not throw it out in every case. .
could be faulty shell casings
take it to a gunsmith and discuss the fault with him as he will be seeing this problem on a regular basis
Nov 04, 2015 | Sewing Machines
My shotgun is not ejecting the shell-
If what you are saying the empty Shell is still in the open ejection area and another is trying to push in..if so your ejected is either worn or has gunk built up around it or your chamber is dirty and causing the just fired shell to stick momentarily...try firing and eject an empty shell without another feeding in and see if it clearly and quickly ejects the empty..if not it is the ejector or dirty chamber the new steel is spring fed so it should not be the poblem ..you can try another spring and see what happens. My bet is a worn or dirty ejector..or a long shot it may be the shells expanding too much do to age damp etc try different ones..good luck..
Nov 10, 2014 | Optics
Shell does not eject slide jams..I pull clip, pull slide back a couple times , shell ejects what is my problem
Hi! Kevin.....bit hard to know !....assuming ammo is correct dimensionally & of good power., & extractor & ejector are in order & chamber is good & slide is free & full sliding......then my first guess would be sticky firing pin not retracting properly thus stymying ejector action.......any stickier & you might get full auto ?......are you puncturing primers ?.. if gas back escape is part of the picture , bullet may not leave barrel . I suggest you do full strip , incl firing pin , clean & remove any burrs ..... worthwhile to run some dummies by hand & see how they behave..........jimbanjo
Jan 16, 2014 | Smith & Wesson SWW-357-R
Mossberg 500, shell will not eject
did you check the elevator to make sure its not applying the pressure on the cartridge interrupter and cartridge stop? or that one or both aren't damaged and over bent. the ejector slot on the bolt isn't damaged, or the action slide bars.
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
I have a shell stuck in the gun and can't get it out!
if it is exploded run a rod through the gun when you break it apart. if it is unexploded be careful - it's probably a rim fire cartridge. use plenty of penetrating oil.
Sep 29, 2009 | Remington Powder Actuated To Power Load...
Slide arm does not go completely forward
My Friend,
It seems you really have outdone yourself! The only thing I can recommend is to go to your local gunsmith ( a gun store could help in the location of one hint, hint) and have them disassemble the old gal. they will assess the damages done by your rookie mistake, and hopefully it's not too bad eh (she's a beauty she is). next time I STRONGLY recommend you take every precaution necessary to not damage you the guns or others. I STRONGLY recommend cleanings after every use, and please be sure to slide the slide arm all the way forward next time. You are lucky you were not hurt.
In my opinion though you may have broken a crucial spring, lock the slide gate shut, and/or dislocated the base of the spring. the shell not fitting I would say is a barrel issue with unburnt black powder, or a small dent in the barrel form the slide mechanism. BUT I HIGHLY recommend you do not try to repair this in your home or take my diagnosis as I have not seen the gun, nor am I a professional gunsmith.
Best Wishes,
KidKRYLON
Mar 22, 2009 | Winchester (026196062448) (20 - 60x70 mm)
Sport & Outdoor - Others Logo
76 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
