Question about Comfort Zone CZ-530 Compact Heater
Looking for legs for CZ530 Comforzone heater - Comfort Zone CZ-530 Compact Heater
Dryer drum turns fine, light on, but no heat.
could be thermostat or bad heater or the door switch or the breaker has tripped one leg
Nov 01, 2015 | Dryers
Need manaual for comforzone pool heater 11
Hayward madeComfortzone heaters and most of the parts are long gone. Sorry
May 20, 2014 | Hayward H-series Electronic Gas Pool...
Heater element only gets 120volts. Should be 240v, correct? Water does not heat up.
Testing voltage on heater can be tricky since elements can test 120Volt to ground all all times.
This is because thermostats only turn off 1 Hot leg in the 240Volt circuit, while the other hot leg remains live. Each hot leg in 240Volt circuit is 120Volt.
http://waterheatertimer.org/B220C.html#120-240
Troubleshoot electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
Try following things in order: Press reset button. Test elements. Replace thermostats.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add comment.
Apr 29, 2013 | Water Heaters
Find filters on a kenmore miser 6 gas water heater
1) Are you looking for air intake screen located on bottom of water heater? Clean with compressed air or feather duster.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Kenmore water heaters are made by AO-Smith/ American
Stand 3-legged water heaters are bricks so air intake is easy to clean.
Dec 29, 2012 | Water Heaters
No hot water at all but power to all elements and to thermostats is there a dip tube in the rheem model 71-40D
Water heater can test for 120V power on elements and thermostats at all times.
That's because thermostats turn off one leg of 240Volt circuit, and not both legs.
You mentioned thermostats and elements, implying two elements and two thermostats, so your water heater is 240Volt.
240Volt breaker might be bad on one leg.
Open following links to troubleshoot
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Yes the water heater has a dip tube.
http://waterheatertimer.org/How-it-works.html
Jul 10, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot or warm water what is the voltage reading susposed to be on the heating elements? I have 122 volts on each terminal on both elements but no action, what am i doing wrong?
If water is totally cold, then upper element is not getting 240V. Since element tested for 120V, then that says upper element is burned out, upper thermostat is bad, or circuit breaker is bad.
Best thing is to buy multimeter and do 30 minute troubleshoot:
Also read information below for understanding how water heater works.
Testing elements for voltage can be misleading.
If water heater has 2 elements, then tank is 240Volts.
240V water heaters have 120V on each element at all times.
So elements have hot 120V power, but they are not turned on until the circuit is complete with 240V.
Open following links to read specifics about 120V and 240V
http://waterheatertimer.org/How-water-heater-thermostat-works.html
240V is made from two 120V Hot wires from breaker box.
Each 120V line from breaker is called a 'leg.'
So 240V circuit has two legs, and both legs need to be turned on to complete 240V circuit.
Water heater thermostats turn off only one leg.
The other leg is Hot all the time.
So when you test screws on an element, for example test between a screw and any bare metal part of tank, then the screw will always show 120V.
That is just one leg of the 240V circuit.
But the 240V circuit is not turned On until both legs are connected.
Every residential circuit needs two wires to complete the circuit, and in the case of 240V, those two wires are both 120V.
When the thermostat turns on, it turns on the second leg to the element and that completes the 240V circuit.
Dec 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heater blower on 2004 Sebring Convertible stopped working. I just replaced the heater resistor 3 weeks ago and all fan positions, 1, 2, 3, 4 worked awesome. I'm looking for a diagram for the interior fuse...
CHECK FOR VOLTAGE AT HEATER BLOWER MOTOR IF NOT YOU COULD HAVE A FAULTY BLOWER MOTOR RELAY.IF YOU HAVE VOLTAGE AT BLOWER MOTOR THEN BLOWER MOTOR FAULTY.
Nov 08, 2010 | 2004 Chrysler Sebring
Common terminal location on a goodman furnace
White wires are commonly the common connection (sorry for the pun). L2 is also considered the common leg. You did not mention if you are looking for high voltage or low voltage common. L2 is your high voltage leg. If the power venter ties into the thermostat circuit, W on the circuit board is the common terminal.
Dec 01, 2009 | Goodman GMS90703BXA Heater
Comfort Zone CZ-530 Compact Heater Logo
Top Comfort Zone Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
