Question about RTO Image 15.0R Treadmill Walking Belt
Image 15 r teadmill belt wont go - RTO Image 15.0R Treadmill Walking Belt
E44 on left screen, 123 on right screen of ironman 150t teadmill
I am trying to track down a similar solution, with no luck so far. I will keep you posted. Am trying to clear a message regarding perform maintenance. The machine will not run at all.
Feb 28, 2014 | Ironman 150t Incline Motor
My Image 15.or treadmill makes a loud, whining highpitched sound when operating. Should it have lubrication?
LUBE the deck belt + rollers bearings .However test the rollers bearing main motor.
If the problem persist time to replace the deck belt old board.
God bless you
Jan 25, 2013 | Exercise & Fitness
My motor is not working, on my teadmill,,, it start for 1 sec and it staps
1) LUBE inmediately deck belt, this happen to due the lack of maintenance. Shut down for to protect the system itself. Maybe you have a WORN a deck belt.
2)LUBE the rollers bearing too.
3) Test the input voltage motor, if there are the motor need repair. See my personal TIPS.
4)Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you.
Nov 23, 2012 | Reebok Rx2000 Treadmill Walking Belt For...
My teadmill is coming on but the belt is not moving
1) LUBE THE deck belt inmediately
2) LUBE THE rollers bearing too.
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the diagram.
God bless you
Jul 21, 2012 | Exercise & Fitness
Teadmill shuts off and shows E1
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Oct 04, 2010 | New Balance Balance 1500 Treadmill
How to turn on my teadmill
Go to iconservice.com click on manual then manufacturer the this M# PFTL56007 for the owner's manual and on page 13 will have the info needed.
Jun 28, 2010 | Proform Crosswalk 500 Treadmill
How can you tighten the walking belt on a Image 15.R treadmill. Im pretty sure that its the belt you walk on that is slipping and not the one under the hood but I could be wrong. Any advice?
If you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 03, 2010 | RTO Image 15.0R Treadmill Walking Belt
Image 15 r treadmill belt is slipping. can I tighten it? if so how??
that can be tightned up,pretty easy to do-just don't over tightn, want to be able to push down on belt 1/4th to 1/2 inch
Jan 08, 2010 | RTO Image 15.0R Treadmill Walking Belt
Where is the thermostat located
Coolant Pump, Exploded View 42398463
IMAGE REFERENCE:
  1. 2O Nm (15 ft lb)
  2. Coolant pump pulley (For poly-ribbed belt)
  3. Coolant pump
  4. Gasket (Always replace)
  5. Thermostat
  6. Connector pipe
  7. 0-ring (Always replace)
  8. Clip
  9. 10 Nm (7 ft lb)
  10. Flange
  11. Coolant pump pulley (For V-belt)
Jun 05, 2009 | 1996 Volkswagen Jetta
Minolta QMS 2350 showing service call 15 xfer belt
Your error means -
Incorrect pressure by or separation from the transfer belt cleaner
Remedy
1 - Check the Belt cleaner positioning sensor pc9 (located at the rear on the left hand side towards the top when looking from the front of the printer)
2 - Replace the Second image transfer roller pressure/separation
mechanisms.
3 - Check the Image transfer roller pressure contact solenoid SL2 (this sits more in the middle behind the printhead)
4 - Replace PWB-A.
5 - Replace PWB-P.
Jul 05, 2008 | Minolta Office Equipment & Supplies
RTO Image 15.0R Treadmill Walking Belt Logo
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
