Question about RTO Image 15.0R Treadmill Walking Belt
RTO Image 15.0 R treadmill motor belt runs for a second then stops
4 Suggested Answers
SOURCE: image 15.0 treadmill will start but stops after 30 seconds to 1 m
how to fix
Posted on Jul 29, 2009
  • 43 Answers
SOURCE: image 15 r treadmill belt is slipping. can I
that can be tightned up,pretty easy to do-just don't over tightn, want to be able to push down on belt 1/4th to 1/2 inch
Posted on Jan 08, 2010
Testimonial: "Thanks for the help. Much appreciated! "
maxtreadmill
  • 832 Answers
SOURCE: How can you tighten the walking belt on a Image
If you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Posted on Mar 03, 2010
The incline and decline not working
Please RUN the software calibration under the HOOD cover from the motor the instruction, for easy diagnose, troubleshooting, and fix it.
God bless you
Sep 17, 2012 | RTO Image 15.0R Treadmill Walking Belt
My treadmill runs for 15 minutes than stops for a minute than start up for 10 minutes than stops, than start up
It is designed to be able to be restarted after about 5 minutes. When it stops, wait 5 to 10 minutes, reset the circuit breaker. Of course you still have the same problem.
The motor contoller board is most likely overheating do to friction, so you're going to need to lubricate the walking belt(this should actually be done every 6 months) you can order a kit on ebay for about 15-20 bucks, it's called " lube n walk ", and no, I don't sell it, but I use it on the treadmills I service.
I recomend you loosen the belt one full turn on each side before you lube the belt, apply the lube and run the treaadmill for one mile without anyone on it and then let it rest for a while.
After that give it a try. if the belt slips, then tighten it back up one turn, but don't over tighten it.
I also recomend using a single outlet surge supressor.
That should solve your problem.
Jan 11, 2011 | RTO Image 15.0R Treadmill Walking Belt
My 15.5 image treadmill lights up but will not start.
I have an Image treadmill model #: IMTL31504.0. It will come on for 1 second and then it appears to lose power. Any thoughts? The belt does run for that 1 second.
Sep 22, 2010 | RTO Image 15.0R Treadmill Walking Belt
CONVEYOR BELT NOT MOVING ON THE IMAGE TREADMILL
This could be because the belt on the motor that turns the belt you walk on is worn out. it has grooves on this belt that must be prominant to stay in the groves on the front roller and motor. The motor belt can be ordered for about 20$ shipped on ebay the motor belt number is 118016 this is a universal belt and fits this treadmil. Before buying the replacement belt check to see if this is for sure your problem. you can tell by opening the front of your treadmill and looking at the belt. You will see worn spots on the motor belt, or as I noticed when mine went bad, it will look like someone threw a bunch of rubber eracer shavings in your treadmill.
Aug 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
How can you tighten the walking belt on a Image 15.R treadmill. Im pretty sure that its the belt you walk on that is slipping and not the one under the hood but I could be wrong. Any advice?
Mar 03, 2010 | RTO Image 15.0R Treadmill Walking Belt
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Image 15 r treadmill belt is slipping. can I tighten it? if so how??
Jan 08, 2010 | RTO Image 15.0R Treadmill Walking Belt
RTO Image 15.0R Treadmill Walking Belt Logo
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
