Question about GE Profile 1.1 Cu. Ft. Mid-Size Microwave - Black
Pem31sm3ss does not turnoff
The microwave does not turn off. I have remove the power plug for more than 2 hours but when I plug it back it still runs. It does not warm the food and the turn table does not move. No matter what I do, it want turn off
    New Friend:
All the units that's mounted for this model have problem closing the door. After you closed the door, press down on the door.
Posted on Feb 06, 2015
  • 833 Answers
SOURCE: GE Spacemaker Microwave Oven JVM1330BW200
all...you should first check to make sure the outlet you're using is good. Really. Next, check internal fuse and thermosafety in the unit. They are both found inside the button area. The safety is about the size of a dime and 3/8 inch thick with two wires. Sometimes they open. They should be continuous. Not it? Let me know.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Above the Cooktop Oven Microwave JVM1533 Turn table does not move
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
In this case, I would suspect the primary interlock door switch.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 12, 2008
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
SOURCE: GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Posted on Jan 20, 2010
  • 1531 Answers
SOURCE: GE microwave oven Spacemaker Moldel / will not warm food
the most likley problem is the magnetron has gone bad.but there are a couple of thermal sensor in the cabinet that need to be checked. one of those could be bad as well.
Posted on Feb 25, 2010
Pem31sm3ss wont shut off
If you wish to get some details about microwave oven repair then check the following link
www.electro-medical.blogspot.com
Jun 28, 2016 | Microwave Ovens
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
I have a GE profile PEM31SM3SS that heats intermittently. This is the second time it has stopped heating but in the past has started to work again sometimes months later. Is there any fix I can do short of...
do this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 08, 2013 | GE Profile 1.1 Cu. Ft. Mid-Size Microwave...
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchenaid vented microwave KHHS179LSS-5 surface light is blinking on and off. Started a couple of weeks ago. Thought I was forgetting to turn the light off but realized it was not me. Went to the...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Apr 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have no power for my GE profile microwave. The model # is PEM31SM3SS. The outlet is good.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 24, 2011 | GE Microwave Ovens
My 4 year old daughter lent against the microwave and has locked the entire key pad. How can I unlock please?
Remove the power plug and keep aside for some time maybe an hour. Plug it back again and it must reset and work.
Set your timer . If not the control unit has an error , leave it off overnight and try.
Aug 27, 2010 | Microwave Ovens
I have the 63252 model....When the microwave is turned on to cook, it runs, there is no heat.... does this microwave have fuses of any kind....
Your oven may have separate fuses for the magnetron and the electronics so I suggest you pull the plug, remove the back and look for an accessible fuse holder. Allow the unit to stand unplugged for at least several hours before removing the back panel as there are components inside that can carry a nasty charge for hours.
Feb 26, 2009 | Kenmore 63252 Microwave Oven
Microwave will turn off a few seconds after start.-
It seems there is something wrong either with the builtin controls or the buttons. It needs to be examine by a professional.
Oct 31, 2017 | LG Over-the-Range Microwave
GE Profile 1.1 Cu. Ft. Mid-Size Microwave - Black Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
