Question about KitchenAid Ovens
E5 f2 on visual oven display
Kitchenaide convection oven will not start and is flashing E5 F2
2 Suggested Answers
BarrettDenCo
  • 1772 Answers
SOURCE: My KitchenAid Superba oven is not heating. Code
Hello and sorry to hear about your problem. The code you have given, will have this problem. I suggest you contact a service person.
F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
I have tried to help you. Please help me by Vote/Rate the response. Thanks and good luck
Posted on Dec 20, 2010
F2E5 showed on the display and the oven turned off
The F2 E5 error indicates that there is a fault between the key pad and the control unit. (The wiring is giving an "open" fault.)
Press Cancel and wait 60 seconds. If the error recurs, you need to get behind the keypad and check that the wiring is securely connected to the keypad and the central control unit. Inspect the wires for any breaks. Check each conductor for continuity on each side of the wiring harness, if possible. Reconnect the wiring and press Cancel again. If the error recurs after 60 seconds, you'll need to replace the keypad or the keypad and control unit. (KitchenAid provides the keypad and control unit as a single assembly for some models.)
If your oven is still under warranty, contact KitchenAid for service.
I hope this helps. Please add a comment with the model number of your oven for details on the appropriate replacement parts.
Feb 17, 2015 | KitchenAid Ovens
Kitchenaid superba oven
Defective keypad, control panel or both.
Nov 22, 2013 | Ovens
Audible alarm sounded--"F2 "appeared on
Your model is actually a 911. Roper (Whirlpool)
The F2 error code is
E0 - Shorted keypad (also called touch pad)
E1 - Keypad cable unplugged
E5 - Cancel key drive line open
E6 - Cancel key drive line open
Solutions:
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 30, 2011 | Ovens
My KitchenAid Superba oven is not heating. Code F2- E5. thank you
Dec 20, 2010 | KitchenAid KEBC107 Electric Single Oven
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
F2 came on the display what does this mean?
need to re set look in manual need to reset time ect this happens alot due to power ottage
May 15, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven givs ma arrer massage C-F later F2 E0
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!##
Oct 02, 2009 | KitchenAid 30 in. Architect II Series 4.3...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Ovens Logo
20 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
