Question about Huawei Metro PCS M835 Android CDMA Video Touch Smart Cell Phone
My huawei keeps restarting itself when i try to power it on
What should I do to delete all configurations of the Huawei S2300?
To delete all the configurations, delete the vrpcfg.cfg file from the flash memory, and then restart the Huawei S2300 switch. The vrpcfg.cfg file cannot be deleted when it is running because it is used as the system file. To delete the file forcibly, perform the following steps:
1. Restart the Huawei S2300 switch and press Ctrl+B to enter the BootROM menu, and then enter the default password huawei.
2. Press Ctrl+Z to enter the hidden menu, and then select option 2 to enter flash memory.
3. Delete the vrpcfg.cfg file from the flash memory, and then restart the device.
Dec 25, 2017 | Huawei Computers & Internet
How to delete all configurations of the S2300?
More related:
Huawei S2309TP-EI-AC
Huawei S2309TP-EI-DC
Huawei S2309TP-PWR-EI
May 17, 2017 | Cell Phones
Hi My Huawei wont charge
fone fell if screen doesn't respond digitizer has gone bad, charger port also damaged I'd recommend getting a new device since it will cost alot to repair that
Apr 18, 2017 | Huawei Cell Phones
Show me the picture how can I put huawei phones in safe mood
To do this, long press your Power button. Then long press on the Power off option. You will then be asked to reboot into safe mode.
When your phone restarts it will not load any Apps allowing you to disable any troublesome ones.
- See more at: http://www.phonetipsandtricks.com/tips/huawei-ascend-mate/how-to-reboot-into-safe-mode-21/#sthash.XufVaXre.dpuf
How do I enter and leave safe mode? When powering on the tablet press and hold the volume down button until the words "Safe mode" appear on the screen, indicating that the tablet has entered safe mode.
To exit safe mode, restart your tablet.
http://download-c.huawei.com/download/downloadCenter?downloadId=66563&version=250940&siteCode=worldwide
Mar 17, 2016 | Huawei Cell Phones
HI HOW DO I UNLOCK MY PHONE HUAWEI MODEL y530-u051?
Try to this, first turn off your phone then hold the power button together with the hi or low volume button, when display is on release the power button but still you hold the volume button,and when see the option on your screen release the volume button and choose wipe all data then push the power button... And it will automatically restart your phone....
take note...files on your phone will be all deleted same with purchase apps
Aug 17, 2015 | Huawei Cell Phones
My HUAWEI won't start up blank screen but battery says 100%.
You should just plug it in just in case that way you know that it is correct. If that does not work then you should restart it.
Hope that helped
Jan 01, 2015 | Huawei Cell Phones
I need the Huawei E5375 mobile MIFI users manual in English
The Huawei E5375 is a customized Chinese version. And it is similar with the Huawei E5372 which is in English version. So, you could find the E5372 user manual, they are the same. Huawei E5372 LTE CAT4 4G Mobile Router
Jan 26, 2014 | 2003 Chevrolet TrailBlazer
Huawei Ascend II hung and I had to remove the battery. When restarted after putting battery back in, it got to "preparing SD card" and an error then appeared that said com.android.huawei.keypadprogramming...
If you have an SD card in the cell phone, remove and restart the phone. If that doesn't work, do a complete reset. Keep in mind that you will lose all the data in your phone when you do that. Please take a backup before resetting your phone.
Sep 13, 2017 | Huawei Ascend Ii
My computer keeps restarting itself everytime i play games? How can i fix this?
It seems your power supply can't supply your computer power as needed so you need to replace your power supply. Use 500 watts pure power supply to avoid this problem.
Jun 23, 2017 | ASUS Essentio Computers & Internet
Huawei Metro PCS M835 Android CDMA Video Touch Smart Cell Phone Logo
19 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
rostit
 Brian Main
Brian Main
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
