Question about Hitachi NV45AB2 Roofing Coil Nailer
Hitachi 45ab blowing air out of trigger - Hitachi NV45AB2 Roofing Coil Nailer
    President:
  • Hitachi Master
  • 1,388 Answers
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Posted on Apr 21, 2014
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I have a Hitachi NV 45AB roofing nailer that is
You replaced all the orings and I take it that you lubed them a little with a light grease. By exhaust valve I assume you mean the plate on top and if so it could be a couple things does the air leak out when you connect the hose and don't do anything if so if you have a dead blow hammer try "tapping" on the top cover with the air connected, some times when replacing the rings the cylinder doesn't seat right away. If it leaks when you depress trigger then I would look for a cut o ring. Let me know and we can fo further
Posted on Mar 11, 2009
How to replace the trigger on a hitachi nv45ab2
Pound roll pin out of black trigger and remove. Turn silver slotted part with screw driver and the two valves will pop out. Usually it's the flat trigger bushing that is bad and makes it leak. I have all parts.
airnailerparts.com
Dec 02, 2014 | Hitachi Tools & Hardware - Others
Blowing air out of trigger
Leaking under trigger could be the ball seal part # 875645 if leak starts as soon as you connect the air hose. If no air leaks when you connect hose but begins to leak when you depress the trigger then replace the oring on the plunger which is part # 874820. If air leaks when you connect the hose and the ball mentioned above is good then most likely is leaking from oring # 876161 installed on cylinder plate (remove head and pull out the plate). Good luck.
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
Air blowes out the trigger when squezzed
the seal inside is ether out of place or cracked gun are cheap buy a new one
Jan 22, 2014 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
My Hitachi NV45AB is leaking air from the trigger air valve. The gun still works if I just keep the trigger depressed and just smack the tip into the shingle.
Remove the 3mm roll pin holding the trigger in place and set aside the trigger plunger (white plastic plunger should have an oring on groove). Remove the fitting that holds the trigger plunger and replace vinyl ball #875645 or check for debris under ball. Good luck with your repair.
Apr 19, 2013 | Hitachi NV45AB2 Roofing Coil Nailer
My hitachi roofing gun leaks air from trigger when not pressed
Two areas to check when air leaks from around the trigger. Rubber ball under trigger pin will cause air to leak, however when good side of the ball falls on the seat, air will not leak for a while. If air is leaking from plunger pin (just in fromt of the trigger pin), remove the head and pull out the cylinder plate to reveal broken oring (oring part # 876161). Good luck with your repair project.
Jun 05, 2012 | Hitachi NV45AB2 Roofing Coil Nailer
Air leak
My Guess is that it needs a new "O " ring or some other form of seal some where round the trigger actuating spindle. Should be quite easy to fit if you can get one the right size
Jun 05, 2010 | Hitachi NR83A2S Framing Nailer, Full Head,...
I just rebuilt the nail gun with all new o-rings and gaskets and when I put the air to it air actually blows the rubber boot off the plunger on the trigger assy.
I am assuming that the boot is blown off when your fire the nailer. This is caused by a loose/worn plunger and valve. If the plunger moves from side to side too much air will flow past the valve and blow off the boot. Most used hitachi nailers will blow this boot. Only way to fix is replace one or both parts. If air leaks past the boot immediately when you connect to air, check oring on plunger A (part# 874-820) or outer orings on cylinder guide and cylinder plate. These outer orings are easy cut while inserting these parts into cylinder. Check orings for nicks. Good luck and post again if you have more questions.
Mar 11, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
I have a Hitachi NV 45AB roofing nailer that is leaking a lot of air from the exhaust hole. I just replaced all of the o rings in the nailer and it did not help anything. Could this be a bad exhaust valve?
Mar 07, 2009 | Hitachi Tools & Hardware - Others
Hitachi NV45AB2 Roofing Coil Nailer  Logo
283 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
