Question about Quantum Audio QCA2000D Car Amp
How to wire my qca2000d to 1ohm - Quantum Audio QCA2000D Car Amp
2 Suggested Answers
SOURCE: QCA2000D Car Amp: Bought a Quantium audio QCA2000D cozmic with no in...
the two outside terminals. the farthest negative and the farthest positive
Posted on Aug 02, 2010
May 18, 2010 | Quantum Audio QCA2000D Car Amp
Safe light is on, on my Boston Acoustics GT-28
its not grounded properly or the subs are not properly wired so make sure you ground wire is screwed to metal not a painted part of the car second check your sub wiring and make sure the subs are not wired at 1ohm if your amp is not 1ohm stable.
Mar 18, 2010 | Boston Acoustics GT-28 Car Audio Amplifier
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Whats the best way to hook up my L7 10''
Hello ereza25,
The best way depends on what amp you are using to power the sub. With dual 2ohm voice coils, you can wire to either a 1ohm or a 4ohm final load. If you are sure that your amp is stable down to 1ohm, that wiring will provide the best power to the sub. But if the amp is not rated at 1ohm (many aren't), then the 1ohm wiring will result in overheating and possible damage to your amp.
The wiring diagrams are here. Hope this helps.
Jun 28, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring hk12x2
Hello jose08042008,
Your sub has dual 2ohm voice coils and can be wired to present a final load to the amplifier of either 1ohm or 4ohms. Unless you have an amp that is stable at 1ohm (not many are), then you will want to use the 4ohm wiring. To wire for 4ohms, jumper the positive terminal of one voice coil to the negative of the other terminal, and connect the remaining positive and negative terminals to your amp. If you know for SURE that your amp is stable at 1ohm, you can connect both positives and both negatives together on the sub and then to the amp. But if the amp 1ohm stable, this will result in overheating, and/or going into "protection" mode, and/or damage to the amp.
Hope this helps.
Jun 13, 2009 | MA Audio HK15X2 Car Subwoofer
How do i hook them up to work for 2ohm's
Hello rcantu76,
If your CVR's are 2ohm (model Nr. 07CVR122), you connect the voice coils in series and then parallel both subs to the amp. If the subs are 4ohm (model Nr. 07CVR122), they cannot be wired to 2ohms. Your choices are 1ohm or 4ohms. According to Rockford-Fosgate's data on the P1000-1bd, it is stable at 1ohm.
To wire the 122's at 2ohms, you would connect the sub voice coils in series (jumper one positive to the other negative on each sub), and then connect the remaining positives and negatives to the amp.
To wire the 124's at 1ohm, you would connect all of the positives and all of the negatives together to the amp.
Hope this helps.
May 11, 2009 | Jl Audio 500/1 Car Audio Amplifier
Cant wire to mono amp
Hello danielperez9,
There are two options for wiring a single 2ohm DVC subwoofer to a mono amp. The first gives a 1ohm load and should only be used if your amp is stable at 1ohm. The second option results in a 4ohm load and would be OK for most amps. Here are the diagrams:
Hope this helps.
May 08, 2009 | Alpine SWR-1222D 12" Type-R Series...
I want to hook up my 2 quad coil woofers to a 1ohm amp but
I would look up "series" and "parallel" wiring on the net. Parallel will lower your ohms, which is good- especially for you since your amp is 1ohm. use 1 channel of your amp (unbridged...bridging an amp could increase output, but will Raise the ohms) connect the positive terminal with a wire that goes to the positive on your first sub, and from there, connect a wire from that same positive terminal to the positive terminal on your second sub. do the same thing with the neg. wire. This is called parallel wiring.
Mar 22, 2009 | X-10 Memphis 15-PRC41 Power Reference 4" x...
Quantum Audio QCA2000D Car Amp Logo
Top Quantum Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Quantum Audio Car Audio and Video Expert? Answer questions, earn points and help others
