Question about Cell Phones
Unable to scan for wifi signal
Lg one day it just stopped getting wifi even on my home preferred network
Tanker944
  • 12 Answers
SOURCE: LG Incite: Connect to a multiple-user WiFi network
To enable or disable Wi-Fi
  1. Choose Start, choose Settings, choose the Connections tab, and then choose Wireless Manager.
  2. Choose the Wi-Fi button. If it is turned off, the button will appear as a lighter color and display an icon marked with an "X".
  3. Choose Done.
clear.gif To set up a Wi-Fi connection
  2. Scroll to Wi-Fi and press ENTER. The device will detect available Wi-Fi networks.
  3. Select the network you want to connect to, and then choose OK.
  4. Select Internet or Work, and then choose Connect.
    If you select a secure network, you may have to enter a network key that is provided by the network administrator.
clear.gif To edit a Wi-Fi connection
  2. Choose Menu, and then choose Wi-Fi Settings.
  3. Scroll to the connection that you want to edit, choose Menu, and then choose Edit.
  4. Make changes as needed, and then choose Finish.
clear.gif To delete a Wi-Fi connection
  3. Scroll to the connection that you want to delete, choose Menu, and then choose Remove Settings.
clear.gif To change Wi-Fi settings
  2. Choose Menu, choose Wi-Fi Settings, and then choose the Wireless tab.
  3. Scroll to the connection that has the settings that you want to change, choose Menu, and then choose Edit.
  4. Change any of the following information:
    • In Network name, enter a name for the connection.
    • In Connects to, select The Internet or Work.
    • If the network is a hidden network, which means that it does not broadcast its Service Set Identifier (SSID), select This is a hidden network.
    • If you want to connect directly to another device or computer, and not to a network through an access point, select This is a device to device (ad-hoc) connection.
  5. Choose Next.
  6. On the Configure Network Authentication screen, do the following:
    • Select the authentication and data encryption methods.
    • Enter the network key information or select the The key is automatically provided check box.
      If it is necessary, ask the network administrator for authentication, encryption, and network key information.
  7. Choose Next.
  8. Select or clear the Use IEEE 802.1X network access control check box.
  9. To use Extensible Authentication Protocol (EAP) or smart card authentication, make the selections appropriate to your choice of authentication.
  10. Choose Finish.
Posted on Aug 05, 2009
  • 4 Answers
SOURCE: Wifi saying unable to scan networks
Hello!
Here are the things you can try for a malfunctioing Wi-Fi on your Galaxy S:
Try turning off your Wi-Fi then turn it on again.
  • Sometimes, this works for me as the Wi-Fi might need a restart so it can try scanning again. You can do so by going to Settings > Wireless and Network > Wi-Fi Settings and ticking the Wi-Fi checkbox.
Turn off your handset then turn it on again.
  • An app that was running on your handset might be messing with your Wi-Fi, so to make all things better, you can restart your handset for a fresh boot. :)
Check if there are actually Wi-Fi networks in your area or the Wi-Fi is too weak.
  • If there aren't any Wi-Fi networks to detect, it can't do anything at all in the first place. Try moving to an area with better Wi-Fi signal.
You can ask me if you have any queries! :) ~azukibean70
Posted on Mar 01, 2011
SOURCE: my Samsung Galaxy s GT-
My wifi keeps turning it's self off?
Posted on Mar 09, 2011
SOURCE: my new LG P970 won't
Go to settings, wireless networks, access points and then hit menu button then add access point and enter same address as the one that you are currently connected to then select the access point you just made and problem should be solved, reason why is there was a default proxy, this should fix your problem
Posted on Aug 22, 2011
  • 18 Answers
SOURCE: Trouble connecting to home wifi
you can contact the service provider.....
Posted on Sep 20, 2011
Why has my mobile phone WiFi stopped working at home?
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps
Jun 11, 2014 | HTC Cell Phones
Wifi problem after upgrading foryo in lg gw620
Please Take To Your Mobile Your Update Please So Your Problem Will Qackly Solve.
Jul 30, 2012 | LG GW620 Cell Phone
Wifi wont connect and some other
well, the signal, may be good, but if theirs a huge amount of people on the same acess point, things get messy. if u have alot of people using the same network, the internet becomes laggy, and even if u have a good signal, the internet can be very laggy, and lose connection alot, it depends on the amount of people using the same network, so at home u have only u and ur family connected, at school more people might be connected to the network than at home.
Jan 21, 2012 | ASUS Computers & Internet
My HP mini has been having trouble connecting to my families wifi. it will be able to detect all the wifi around my home and connect to them but when it detects mine (at my house) i click connect but then...
Remove the network from the preferred network list which can be found in control panel.
Then try to connect it oncemore.
If u can tell me the OS, i can help u in locating the preferred network list in control panel.
Nov 06, 2010 | Computers & Internet
I have a toshiba x300, it always connect to other wifi connection? how can I block the other wifi signal? I already uncheck the automatic settings of the other network and delete it from my preferred...
REinstall wi-fi adaptor in device manager
Just go to device manager and expand network adaptors.
Right click on wireless adaptor and select UNINSTALL option
REstart laptop and connect to your network
Thanx
Sep 14, 2009 | Computers & Internet
Will not stop scanning for networks...
One other issue I always encounter is that I have to disable both of the "power conservation" settings that would allow the Axim to shut off the WLAN radio when the battery goes low. Having them enabled (which happens by default) seems to keep my Axim from locking onto our WiFi. When I disable them, I get an immediate strong connection.
You can find these settings under the Dell WLAN ultility.
Oct 22, 2007 | Dell Axim X51v Pocket PC
Cell Phones Logo
10 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
