Question about BOSS AUDIO SYSTEMS BV9560B Car Video Player
Video not available while driving - BOSS AUDIO SYSTEMS BV9560B Car Video Player
How to download avchd files
There are a ton of HD videos available online that you can download and convert to AVCHD videos so that you can burn them to regular DVDs and play them in a compatible Blu-ray player. For example, Vimeo has a large selection of sample AVCHD content. Both AVCHD's MTS and MP4 file formats support 720p, 1080i, and 1080p video resolutions. When downloading videos you should try to capture it at the highest resolution (1080p) possible. However, that said if your video player or TV only supports 720p resolution then that's the format you should select when downloading a video.
RealPlayer Plus does not recognize MTS files. When using RealPlayer Plus to burn HD video onto a regular DVD, look for HD content in the MP4 format like the Vimeo screenshot below. If the resolution you want is only available as an MTS file, you will need to convert the MTS to the MP4 format using third-party software in order to burn an AVCHD DVD with RealPlayer Plus.
For More Detail - http://www.real.com/resources/download-convert-avchd/
Aug 27, 2014 | SanDisk MobileMate SD Plus 5-in-1 Media...
Truly fc606 video converter download
Truly can advise whether a video converter program is available.
May 24, 2014 | Truly FC-606 1GB MP3 Player - Blue Intenal...
Sega genesis model 1 reset button stuck
YouTuber Challenge - Cracked Mega Drive Mobo - Let's Repair - Console Rescue
RetroGameTech
SubscribeSubscribedUnsubscribe58,03658K Loading...
Working...
Add to
Want to watch this again later?
Sign in to add this video to a playlist.
Sign in Share More
  • Report
Need to report the video?
  • Sign in to report inappropriate content.
    Sign in
  • Transcript
  • Statistics
29,661
717
Like this video?
Sign in to make your opinion count.
Sign in 718 6
Don't like this video?
Sign in 7 Loading...
Transcript The interactive transcript could not be loaded. Loading...
Rating is available when the video has been rented.
This feature is not available right now. Please try again later.
Published on May 30, 2013
Recently I was challenged by fellow YouTuber Daz, cojonesdeloro, to rescue his badly damaged Japanese SEGA Mega Drive. To add to the problems, his console was also what is sometimes referred to as an Asian PAL Mega Drive. Basically an originally Japanese console which has been "converted" (butchered
Apr 10, 2012 | Sega Genesis Console
I have a sony handycam DCR HC28E. I do not know how to transfer videos from this handycam to my laptop. What should I be doing?
dear sir .... There are many kinds of video capture .if your camera is attached to your laptop check if you can simply ACQUIRE VIDEO in movie maker software available inside XP windows, check programs files folder in your drive in which windows is installed . check picture if your confused more over there are devices available in market click here or about info click here
do vote if it helps
Apr 03, 2011 | Sony Handycam DCR-HC28 Mini DV Digital...
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
How do you transfer video on the hard drive to the memory stick?
Unable to transfer a video recording made on the hard disk drive to the Memory Stick Duo™ media Solution
sp.gif sp.gif Do the following before attempting to copy movies to the Memory Stick Duo media:
  1. Ensure an Image Database File has been created on the inserted Memory Stick Duo media.
  2. Ensure there is enough space available on the Memory Stick Duo media.
NOTE: For model-specific information about how to transfer a video recording, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Jul 18, 2010 | Sony Handycam® DCRSR45 HDD Camcorder
USB MASS STORAGE?
Go to your "my computer" icon on the computer and you should be able to see all available drives on the computer. Your camera should appear as an external hard drive. You can open the drive and then open the files in the drive. Simply click and drag the files from the camera to your video folder on your main hard drive and you are good to go. Windows Media player should play the videos....or use an editing software like power dvd.
Oct 05, 2009 | JVC Everio GZ-MG30US Camcorder
Computer will not boot.
Double check all connections and then remove anything not needed. Remove video card and try onboard video if available, remove all but one mem module, any cards and disconnect all drives. If you get video at this point, shut down and reconnect drives and components one by one. It helps if you have known-good parts to swapt as "new" does not always mean good.
Feb 17, 2009 | ASUS Computers & Internet
Information used- capacity used and available
Re: deleting the files, did you drag the files into the trash bin and then empty it? The files don't actually leave your drive until you 'Empty Trash' on your mac's doc. Hope this helps, not sure about your startup disc problem.
Apr 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
BOSS AUDIO SYSTEMS BV9560B Car Video Player Logo
24 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Jerry Umali
Steve Sweetleaf
Steve Sweetleaf
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
