Question about Yamaha Remote Control RAV383 p/n:WN983700
Sound from tuner but no sound from tv
Remote control problems - I can select tuner on my remote and get sound but no sound when I press cbl/sat
SOURCE: sound
I'm assuming you you have a basic TV to receiver hookup. Make sure you have the TV audio video output going to the receiver input.
Posted on Sep 01, 2007
VOTIT
  • 2071 Answers
SOURCE: Remote do not want to accept satellite tuner code
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
Posted on Jul 25, 2008
Marcos_Ce
  • 71 Answers
SOURCE: DTV Cable No Sound
Check if DTV/CBL is set receive COAXIAL or OPTICAL inputs. Good luck
Posted on Nov 23, 2008
  • 6 Answers
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: Sound from tuner but no other devices
The RX-V365 cannot process audio from the HDMI cables (you will still be able to hear it on your TV), you will need to run a seperate coaxial or optical cable into the audio input for the relevant component on the back of the RX-V365.
Posted on Jan 04, 2010
Toshiba model 36A43 a Universal remote, a HD Digital Antenna the TV's settings menu no antenna as a auto ch. program search. Has TV/CABLE, I tryed cable didn't set.
I've checked the specs: of your TV. Its original remote control number is "Toshiba CT-90157". This remote control have a slide switch by the left side of it, [a selector switch]; that selects inputs TV, CBL/Sat, VCR, and DVD. You have to select the slide up position to select the TV, to select the TV function by its buttons. Just have to slide one step down to select the input to CBL/SAT; to select the CBL/SAT function by its buttons.
But, without a remote control, you can seect the TV/Video function by its front panel controls. There is press button switch, just right side of its Menu button. For each press of it, the set's input selection will change from TV to Video and vice versa.
Just press this button to select the TV as the input. Then only, the antenna socket at its back will turn effective. If you can't select input by this way, the input selector switch; specified above, has the fault, or the input selector IC inside the circuit board is faulty. Just try this after a Hard Reset to this set, and then check. If it do not help you, contact any service technician, or the authorized service center for Toshiba.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 22, 2016 | Toshiba Televison & Video
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works.
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Lost code booklet for my oneforall remote
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Sanyo TVs is: 0154.
The codes for RCA DVDs are: 0522, 0571, & 0717.
The codes for Magnavox DVDs are: 0503, & 0675. These may or may not work with newer Blu-Ray players. Since you have two disc players, you will need to reassign the CBL/SAT key to act as a second DVD key.
I don't believe the URC-3021 stores codes for surround sound amplifiers: it has only three function buttons: TV, DVD/VCR and CBL/SAT.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Feb 13, 2010 | One For All URC-3021 Remote Control
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
I need the directions on how to set it up.
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Repeat the process with the CBL/SAT button to program for your sat box.
Hope that helps.
Oct 20, 2009 | One For All URC-3021 Remote Control
I need remote control code number for motorola dvr 6416 III
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
Dec 01, 2008 | Arris DCT6200 DTV Receiver
Ph601s universal philips remote it controls 6 devices tv vcr dvd cbl sat cd
I have a sharp a philips dvd a hitachi vcr apinoneer sound system
Feb 09, 2008 | Televison & Video
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
Yamaha Remote Control RAV383 p/n:WN983700 Logo
16 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
