Question about Toto Home
How to adjust water spray in toto bidet - Toto Home
3 Suggested Answers
SOURCE: SB-620 Magic Clean Bidet
CALL 800-681-0753 FOR PARTS
WWW.BIDET1.COM
Posted on Feb 26, 2010
  • 92 Answers
SOURCE: K-4711 BIDET SEAT NO LONGER
well firt thing I would do is check the wate supply make sure you have that to the fixtures. Now the next thing I look at is the valve that is opend and closed by power. It sounds like a wire and power thing more than anything else.
best of luck and be safe around power.
Tom
Please take a second to rate us so we know if we are doing a good job for you. With out feed back we would not know how to fix us :)
Posted on Sep 10, 2011
How to adjust water level in totoST743S toilet
most of these have a screw adjustment on the fill assembly inside the tank...screw up or down to adjust....try one way or other to see which works
Sep 08, 2014 | TOTO ST743S#01 Drake Toilet Tank, Cotton
How do I stop the water from filling the tank on a toto ST794S toilet
try using the adjustment screw on the fill value inside the tank...up or down try both to see
Jul 07, 2014 | Toto Home
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to adjust...one or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
Water level adjustment
If it has a ballcock bend the ball upwards till you have a high enough water level
Nov 26, 2013 | Toto Home
Bidet wand malfunction
You may have another malfunction here. Get your manual and see what it says under troubleshooting.
Jan 17, 2013 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Toto Drake does not fill the bowl to the level of other same toilet. Water level in bowl is low.
Water Level Adjustment
1. To adjust, simply turn upper half of valve counter-clockwise to unlock, pull up till water line on valve is level with water line marked in tank, Fig.C then turn clockwise till valve snaps into locked position.
2. Turn on water supply to fill tank.
3. Tamper proof key is optional, and may be used to simply to prevent further adjustment once final setting is achieved. Fig D
Jan 28, 2011 | Toto Drake ADA Compliant Toilet with...
Water leaking on floor...when flush..no urine water
Before you flush the toilet, take the top cover off the tank.
Then flush.. Sometimes water sprays from the float valve,
sprays up against the underside of the cover, then runs down
the back of the toilet.
All my best to you.
LeRoy
Nov 01, 2010 | Toto - Toilet - One-piece - Ultramax -...
Have toto g-max valve that does not shut off. how fix?
you can adjust the float out to stop water flow there should also be an adjustmen where the arm attaches to the valve. it is possiable that your valve is bad . if so they are reletively easy to change out.
Aug 20, 2009 | Toto Drake ADA Compliant Toilet with...
Home Logo
32 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
