Question about GE 24 in. GSD500X Built-in Dishwasher
Samsung dishwasher leaks during rinse cycle
Run the dishwasher and leaks during rinse cycle, checked all hoses and supply lines and they are not leaking, ordered a seal for front door but haven't replaced yet but don't think thats the problem, wondering if it could be seal on pump, but would leak when draining
futureloginn
  • 734 Answers
SOURCE: leaking water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
  • 9 Answers
SOURCE: I have a GE 24 in. GSD4030Z Built-in Dishwasher that leaks
you may have a pinhole in your drain hose
Posted on Apr 20, 2009
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
  • 3 Answers
SOURCE: leaks while running
The water at the bottom is normal if you open it during the cycle. Leak means you need to replace the L-shaped black, molded gasket that is in the lower left or right of your door opening. Replacement is easy - requires no tools. Part can be purchased for about $10 each at Sears parts department.
Posted on Aug 16, 2009
  • 74 Answers
SOURCE: My GE Nautilus dishwasher leaks. Water comes out
it should be replaced.
Posted on Oct 24, 2009
Samsung dishwasher leaks in left bottom corner of dishwasher during rinse cycle
if it is the rear corner then you may have a leak in the drain line. take off the kick panel and see if you can tell where for sure it is leaking.
May 16, 2014 | Samsung DMR57LFS Stainless Steel Builtin...
Tip
How to troubleshoot your dishwasher
<span>Instructions</span> <ol> Dishwasher Does Not Run <li> <br /> Make sure the power is on, door is latched and controls are set properly.<br /> </li> <li> <br /> Look to see if the door switch, timer or selector switch are defective. Solve this problem by using a screwdriver to adjust the door latch's strike slightly.<br /> </li> <li> <br /> Confirm that the power cord is plugged into the electrical outlet under the sink (if applicable).<br /> </li> Dishwasher Won't Fill <li> <br /> Check your hot water supply stop valve under the sink. Turn it counter clockwise to ensure that it is open.<br /> </li> <li> <br /> Turn off the power and wait for your dishwasher to cool.<br /> </li> <li> <br /> Look inside for a float located at the base of the unit. Lift out the float device and clean around the tube. Rinse off the float and reattach it making sure it moves up and down freely.<br /> </li> Dishwasher Doesn't Drain <li>Remove the air gap cover (short chrome cylinder located at the back of your sink) and clean it using a wire.<br /> </li> <li> <br /> Check the drain hose for kinks and blockages.<br /> </li> <li> <br /> Shut off the power to your dishwasher and remove the strainer located at the base of the cabinet under the bottom spray arm. Scrub it clean then reattach it to the appliance.<br /> </li> Dishwasher Leaves Film on the Dishes <li> <br /> Add a rinse additive to your washing cycle and see if this solves the problem. In addition, do not pre-rinse your dishes prior to placing them into the dishwasher. Food particles allow the detergent and drying agents to work more effectively.<br /> </li> <li> <br /> Listen to the spray arms during a wash cycle. If they appear to be moving too slowly, use a wire to clean out the spray holes.<br /> </li> <li> <br /> Make sure the dishes haven't blocked the detergent dispenser or jammed the spray arms.<br /> </li> Dishwasher Leaks <li> <br /> Cut back on the amount of detergent used during the wash cycle. Sometimes this alone will solve your problem.<br /> </li> <li> <br /> Make sure the appliance is level by adjusting the front feet up or down.<br /> </li> <li><br />Take off the lower front panel and check the hoses for leaks.<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_2120626_troubleshoot-dishwashers.html#ixzz18lyYrfk2"><br /></a></span>
on Dec 21, 2010 | Dishwashers
Hi, I have a Maytag Mdb8959sas dishwasher that was leaking during a normal wash cycle. I pulled the dishwasher out from under the counter and saw that it appears to be leaking directly below the point...
I will assume that you have cleaned gasket around door and at washer. Quite often a build up of scale at lower gasket surfaces is all that is causing leak.
Feb 19, 2014 | Dishwashers
Dishwasher leaks during rinse and wash cycles
Look carefully to see the place of the leak ,If it is from the door gaskets, you will need to replace the seal gaskets. If not check if the drain hose clips are loose, the hose is damaged or if the joints are bad. You can tighten th clips or replace the hose. Use a Good light to probe when the cycle runs and get to the fault which is most imoportant, the rest should be easy. Good day
Aug 12, 2010 | Maytag Dishwashers
The washing machine never runs a complete cycle...it never performs the rinse and spin...always displays a 'nf' code it has never run a cycle completely through
- Foreign material is entering the water supply valve.
- The water supply valve terminal is not connected.
(Wire disconnected)
- The warm water and rinse connectors are wrongly
connected to each other.
- This occurs if the PCB terminal from the drain hose
to the detergent drawer is not connected. Check
whether the transparent hose is folded or torn.
- The cold and warm water supply hoses are wrongly
engaged into each other.
- The temperature of the water supplied through the dry
valve during a dry cycle is sensed as higher than 70
˚C.
The water
supplied for 1
minute drying
the drying cycle
is 0.3 ~ 0.4 L.
- The water temperature is sensed as higher than 50 ˚C
in the Wool or Lingerie courses.
Dec 27, 2009 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Dishwasher runs though cycles but fails to drain in the final cycle
Hi...
If you dishwasher fails to drain you need to check this following:
  • Check sink drain and drain hose for restrictions
The drain hose and recirculation hoses can be responsible for leaks. The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
The timer motor regulates the length of time power is routed to each component. If the timer motor does not function properly, it can result in a wide range of problems. Common symptoms include sticking in a cycle, cycle times running too long, or failure of the dishwasher to start at all.
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | Dishwashers
My frigidare diswasher is leaking from a left side black hose
Check the hose first - it could be split or damaged esprcially if it's old. Check all the clamps to be sure they are tight. Chack all connections to the dishwasher and drain spur under the sink. Check the drain trap fro any leaks.
Mar 27, 2009 | Frigidaire Dishwashers
Leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Feb 05, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Hobart lx30 : rinse cycle
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
May 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
112 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
