Question about Roper Clothes Dryer High Limit Thermostat Replacement Dryer Thermostat
Where is the heater element on a roper gas drier RGX-5634RQo
2 Suggested Answers
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
Low heat from roper clothes drier
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Roper Dryers
Roper dryer timer will not advance and there is no
It wont advance because the heater isnt functioning.
Check to see element reading then temp. thermoststs normally found on heater body.
Jun 06, 2010 | Roper REX4634KQ Electric Dryer
REX4634KQ Electric Dryer: heater element will not come on...
heatman101
May 18, 2010 | Roper REX4634KQ Electric Dryer
Electric dryer not heating...works fine, but no heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 04, 2009 | Roper RGS7646KQ Gas Dryer
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Roper electric drier will not turn off or heat happened suddenly
Replace the heating element. Located in the backside of the dryer
Jan 04, 2009 | Roper REX4634KQ Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Roper Drier no heat and continuous run for two hours
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Oct 20, 2008 | Roper REX4634KQ Electric Dryer
Roper Clothes Dryer High Limit Thermostat Replacement Dryer Thermostat Logo
27 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
