Fuji xerox ducument II 3000 error code 089-311
Machine just shuts down - will not start
pdouglasss
  • 125 Answers
SOURCE: Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Posted on Jan 10, 2009
pdouglasss
  • 125 Answers
SOURCE: Xerox Workcentre c2424 Error Code "37,030.48"
Hi Ian_a_nicol:
error code # 37,030.48 means X-axis motor disconnect. The X-axis motor (second phase) is not drawing the expected power from the power supply. you can do the following to determin if the X-axis motor is bad.
1. Run the X-axis Drive test and if it passes
replace the electronics module, if not see #2.
2. Check the X-axis motor wiring for damage
or replace X-axis motor.
3. Call Xerox to have them come out and run the test and determin if it is the electronics module or the X-axis motor, but is one or the other.
pdouglasss
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
  • 33 Answers
SOURCE: for document centre c250 fuji
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Posted on Sep 08, 2010
micromatikal
  • 2777 Answers
SOURCE: Xerox Workcentre C2424 error code
That is a serious error code indicating hardware failure. Anything with a 07 is a major fault inside the machine. I am not seeing that exact error code referenced anywhere, but I can tell you that it is going to need service for certain. There is no simple thing you can do to get it back to functioning, unfortunately it will require a Xerox service person.
I am so sorry about that, if you really want to know what the error code is specifically referring to please reply here and I will continue to track it down for you, but thought I'd let you know right away that it is something major for sure.
Thanks
Tim
Posted on Oct 27, 2010
042-326 error code on Fuji Xerox ApeosPort II 7500
Not good news.
The ibt belt needs replacement. This is a large smoth blackbelt also known as a accumulator belt. It has a silver reflective marker on its edge and due to wear or damage the sensors cannot see it as it rotates. It will require replacement by a technition.
Jan 27, 2015 | Xerox Office Equipment & Supplies
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
Xerox docucolor 252
http://www.support.xerox.com/support/docucolor-242-252-260/support/enus.html?associatedProduct=dc242-252-260-built-in-controller
Replace any new toner you put in the machine and shut it down for 2 min then power back on. If that doesn't fix it you will have to call Xerox service to replace a sensor that may be broken.
Jan 03, 2014 | Xerox Office Equipment & Supplies
Can you tell me what error code 124-315 means on Xerox Docucentre-II 2055 ? and what the recommended fix is. (Multifuncton printer). Thanks, Gajj
hi
regarding your error go to following link
http://www.copytechnet.com/forums/xerox/36062-xerox-docucentre-ii-2055-error-016-315-a.html
Jul 24, 2010 | Office Equipment & Supplies
Any Windows 7 64bit driver for Xerox Docuprint P8ex? The one posted by Droidd is probably 32 bit and does not work in Windows 7 x64. Thanks.
Hi, The Xerox DocuPrint P8ex understands PrinterControlLanguage of version 5e or 6 (PCL 5e or PCL 6). So actually you can use driver from every printer supports PCL 6. Driver for "Fuji Xerox AP-II C2200 PCL 6" working very well for me on Windows 7 64bit. Steps to install: From Device Manager -> Other devices ->Right click on DocuPrint P8ex -> Update Driver Software -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next
May 12, 2010 | Compaq Xerox DocuPrint P8ex Laser Printer
37 people viewed this question
jasbo
jasbo
