Question about Garden
How do i change the blade on my victa tilt a cut edger
How to change the blade
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
moretons
  • 155 Answers
SOURCE: change the blade
try this site its called pats small engines just look up your model and it will show you a diagram
Posted on Jul 26, 2009
moretons
  • 155 Answers
SOURCE: can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Posted on Aug 04, 2009
RonPark
  • 855 Answers
SOURCE: can not start garden edger made by mclane
O-kay engine and motor are the same. I'll have to do some checking on this one and I'll get back to you.
Posted on Oct 02, 2009
SOURCE: i would like to get a manual foe a victa tilt a
where can i by parts for a Victa Line Trimmer????? The coil snapped.
Posted on Oct 07, 2009
Where can I purchase blade bolt set CA09164 and felt caps and washer set CA09028S for old toe cutter victa lawnmower?
i am sure that the bolts come with the blades as sets and there hasn't been a change since victa started
Talk with a mower shop as they have a selection of bolts and kits
Mar 29, 2017 | Garden
UNEVEN GRASS CUTTING
The most common cause of uneven grass is tire pressure of the machine. Even though they may look like they have air, when you go around a corner it may droop down on that side. If the mechanism is intact, there is no reason for it to change while riding. Or possibly you have a bent hanger.
Dec 15, 2011 | Garden
The edger is not cutting very well. Any tips to make it work better?
You said cutting, not running, so I suggest removing the blade and sharpening on a grinder or buying a replacement blade.
I hope you find this very helpful.
Aug 21, 2011 | Black & Decker Le750 Lawn Edger
I have a problem with my ride on mower. we need to replace the belt that drives a twin cutting disks on a Victa 4013TX but cannot find any diagrams to help.
4013 HT is a Victa with a 13hp briggs and stratton engine normally with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Jan 08, 2011 | Garden
Looking for a victa pro 12 ride on mower parts catalogue
what year? and if you can post a picture it can be more helpful. Victa ride ons were made by other manufacturers with Victa stickers on them.
Oct 02, 2010 | Briggs & Stratton Garden
I have a troy bilt riding lawn mover, it cuts the grass uneven, changed blades thinking it was the problem, but it wasn't. do they have any kind of adjustments for the blades?
The best bet is to work on the deck with it removed from the tractor. You may find the bearings are out in one of the spindles. Quite often someone hits something and the deck housing is bent where the spindle bolts to it. Use a tape measure and measure the distance from the deck to the blade. Compare the two spindles (3 if it's 3 blades) . You'll find one spindle is tilted so that it is not 90 degree to the deck. What I do is once I've located the offending spindle, and which direction it is tilted, I remove the blade, slide a piece of pipe about 4' long over the spindle (usually 1-1/2 or 2" pipe) so it clears the hub and bend it. Then I reinstall the blade and measure it again.
Jul 18, 2010 | Troy Garden
I would like to get a manual foe a victa tilt a cut
Sep 11, 2009 | Garden
Trouble un-screwing edger blade bolt
It may have left handed threads and needs to be turned clockwise to unscrew. As for sharpening an edger blade...it won't cut any differently. That short blade, traveling that fast and rubbing against concrete is going to do it's job, sharpened or not.
Jun 20, 2009 | Garden
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
