Question about Sony Car Audio & Video
CDX-GT565UP connection to a 2003 ford focus
It shuts off after being on for about 3 seconds, also the antenna seems to slide out of the designated slot and i have one loose component that isn't connected to the radio at all, is this the problem?
natenash7986
  • 53 Answers
SOURCE: "Antenna" prompt
your sure connect antenna is bad that is why you get this message or you have something hooked up wrong check the power and ground on the unit if it has one .... some have it, some dont but most of the time its just a bad wire
Posted on Sep 24, 2008
emissionwiz
  • 76846 Answers
SOURCE: Radio - 2003 Chrysler 300 M
A antenna issue would be all the time, not come and go, this is what I have learned from 100's of repairs, I would suggest you make sure the radio has a good ground to the chassis, a poor ground will cause these kinds of static issues.
Posted on Oct 20, 2008
motor1258
  • 6674 Answers
SOURCE: 2003 Ford Focus radio antenna broken off.
Should be a dome light in the interior that lines up with antennae on roof if it's same as I remember. Remove interior light and there should be screws in there holding base of antennae to roof. If it's just a broke off mast, try to unscrew stud from base & replace.
Posted on Jan 10, 2009
  • 184 Answers
SOURCE: Cant tune radio
IS YOUR AERIAL CONNECTOR CONNECTED
Posted on Apr 05, 2009
  • 15 Answers
SOURCE: 2001 Ford Focus stalls momentarily and randomly
Check out this site:
http://www.motortrend.com/cars/2001/ford/focus/recalls/index.html
Posted on May 18, 2009
What causes engine to ABRUPTLY shut off while driving ?
2004 Ford Explorer Engine Stalls/Cuts Out While Driving: 31 ...
www.carcomplaints.com/Ford/Explorer/.../engine/engine_stalls_cuts_out...
... 2013 · 2012 · 2011 · 2010 · 2009 · 2008 · 2007 · 2006 · 2005 · 2003 · 2002 · 2001 · 2000 ... 2004 Ford Explorer engine problems: engine stalls/cuts out while driving ...to overheat and slide out of its socket, causing the engine to shut off. ..... Suddenlyat 30-35mph, my engine just died and i cannot control the steering wheel.
2005 Ford Escape Engine Shutdown While Driving: 24 ...
www.carcomplaints.com/Ford/.../engine/engine_shutdown_while_drivin...
The 2005 Ford Escape has 24 complaints for engine shutdown while driving. ...January 22: Ford Ranger Driver Killed by Takata Airbag in South Carolina news ' 2 days ago; Ford Focus Door Latch ..... I was 80 miles from home when the engine shut off. .... No one could seem to determine the true cause of the problems.
Ford Ranger Stalling/Dying Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Ranger
Nov 2, 2007 - 31 posts - ‎21 authors
Learn more about Ford Ranger at the Edmunds.com Car Forums! ... cut off a couple of times then it started happening more frequent while driving. ..... the other day I was driving down the highway and it just shut off, no warning .... 2000. when it gets overheated the circuit shorts and causes the engine to die. Ford Expedition engine cutting off while driving
Oct 24, 2009
Mercury Mountaineer Start Stall Idle Problems
Oct 1, 2007
More results from forums.edmunds.com
Jan 27, 2016 | 2003 Ford Ranger Regular Cab
How do you remove the starter out of a 2003 ford focus?
Removal
1. Disconnect the car's negative battery cable.
2. Raise the car's front end with its floor jack and support it on axle stands; make sure you set the parking brake first.
3. Disconnect the air cleaner's outlet tube from the throttle body if your model has an SPI engine; loosen the hose clamp with pliers.
4. Unbolt and disconnect the power-steering pump using your wrench and set the pump aside. Do not disconnect or stretch the pump's lines. This should only be needed if your Focus has a 2.3 liter engine.
5. Unscrew the starter motor's mounting bolts using the wrench and then pull the motor off the dowel sticks on the transmission housing; you might need to angle the motor to remove it. Unscrew the nuts and disconnect the motor's wiring.
Installation
1. Connect the wiring and nuts to the replacement starter motor and slide it onto the dowel sticks, then tighten the mounting bolts with the wrench.
2. Reconnect all components that were disconnected--bolt the power-steering pump in place and connect the air cleaner outlet tube using its clamp.
3. Lower the car off the axle stands and reconnect the battery cable
Mar 02, 2011 | 2003 Ford Focus
FIRING ORDER
2003 Ford Focus 2.0 liter SOHC L4 VIN "P"
2003 Ford Focus 2.0 liter DOHC L4 VIN "5"
or
2003 Ford Focus 2.0 liter DOHC L4 VIN "3"
Hope helps (remember to rate this answer).
Dec 13, 2010 | 2003 Ford Focus
I replace water pump and i time it just by the manual but wont start on ford focus 2003 2.0L
The design of the ford focus is pretty bad. If you didnt do the timing perfect the pistons will hit the valves. This is called a zero clearence engine. You need to check compression in the cylinders and make sure they are in spec.
May 10, 2009 | 2003 Ford Focus
2001 Ford Focus suddenly died
have you tried to wiggle the key when the motor is running and does this duplicate the problem...if so replace the ignition switch.
Mar 29, 2009 | 2001 Ford Focus
Jan 10, 2009 | 2003 Ford Focus
2003 ford focus fuel filter replacement
  1. Depressurize the fuel system. For additional information, refer to Section 310-00 .
  2. Disconnect the battery ground cable.
  3. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  4. Disconnect the evaporative emission pipe.
  5. Remove the fuel filter outlet pipe. For additional information, refer to Section 310-00 .
  6. Disconnect the fuel filter inlet pipe. For additional information, refer to Section 310-00 .
  7. Remove the fuel filter and bracket.
  8. Remove the fuel filter.
    1. Remove the bolt.
    1. Slide out the fuel filter.
you may need a special tool to release the qucik connects for the fuel lines from the filter.
Dec 31, 2008 | 2003 Ford Focus
Sony cdx mp70
It may be that the remote lead on the amp has been connected to the auto antenna lead on the radio instead of the amp remote lead and because the auto antenna goes down when the cd is inserted it is turning off you amplifier, check the connections behind the radio or if there is a light on the amp check if the light goes out when you insert a cd
Oct 05, 2007 | Sony CDX-MP70 CD Player
Car Audio & Video Logo
22 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
